  New Posts New Posts RSS Feed - Where do these go?
Where do these go?
Bigoutfit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bigoutfit Quote  Post ReplyReply Direct Link To This Post Topic: Where do these go?
    Posted: August-02-2011 at 3:18am
I am working on my 1973 Correct Craft Skier, which was a pile of parts two weeks ago. In the bucket of stuff are these two parts. Can anyone tell me what and where they go?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bigoutfit Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2011 at 3:53am
This is 7 1/2 inches long.
FLSKIER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FLSKIER Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2011 at 11:46am
The First piece looks like a banjo fitting for a fuel line to the carb.and the Hex rod is a Oil pump drive from the engine.
82 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2011 at 11:56am
Don't reuse that oil pump shaft,they are cheap and your missing the retaining clip. If you were to reuse and after it's all together, if you were to pull the distributor the shaft will drop into the oil pan.
