  New Posts New Posts RSS Feed - Foam for floor and stringer projects
h2ojerm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote h2ojerm Quote  Post ReplyReply Direct Link To This Post Topic: Foam for floor and stringer projects
    Posted: August-23-2011 at 12:21pm
I just wanted to share this source for foam for floor and stringer projects.
The higher density product is stronger and better for keeping moisture out.
http://www.shopmaninc.com/foam.html
Thanks
Jeremy Boughman
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2011 at 12:47pm
Jeremy,
Thanks for the tip but FYI, U.S. Composites is where 90% of our members doing stringer jobs have been getting all their supplies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote h2ojerm Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2011 at 12:57pm
I haven't been on here in a while. I have used their stuff before with good results. I had seen some posts talking about great stuff and other foams, just wanted to recommend a good high density foam. Glad to know most are aware.
Thanks
Jeremy Boughman
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2011 at 9:56pm
Jeremy,
Thanks
Jeremy Boughman
I feel that the recent posts you found using the "great Stuff" foam were just a recommendation on a repair for a void under the floor. I would never recommend it for a total stringer foam job. BUT, I do remember one member using it!!! the "great Stuff" foam being a moisture cure, the density is in question!!
