  New Posts New Posts RSS Feed - Burning Too Much Fuel
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Topic: Burning Too Much Fuel
    Posted: September-02-2005 at 3:11pm
You can set your clock by it.... I burn 6 gallons per hour of boating.
Just how much fuel do you guys burn?
If I have a problem, I really need to know.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2005 at 3:28pm
Jim the power valves do almost nothing to meter the gas, only what minimum vacuum the valve permits gas through the PVCR's, and with a vac gauge you can estimate when they are likely opening.
The main jets and PVCR's drilled into the metering block meter the gas on the primary side, and a metering plate on the secondary side meters tha gas on 4160s, else its similar on both sides for 4150's.
Perhaps try this...Buy a couple new plugs...
Install a new plug and do a WOT run and then shut down immediately and photograph the insulator of the plug. Cut away the threads of the plug with a hacksaw.
Then disconnect the secondaries, install a new plug and do the same WOT run and examination. Post the insulator photos and then we'll have something tangible to discuss.
Then reply with your timing numbers at idle, 1500, 2500, 3000 rpm and final(max)
Also, perhaps tubing at 15-25 mph is probably not a very efficient speed for that hull.
River Rat to Mole
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2005 at 3:29pm
Jim, wouldn't surprise me if your boats burns
more than modern engines. Just as cars in the sixties burned more than modern engines, even with the same cubic inches.
My 2001 Super Air with GT 40 averages about 5 gph. Little more if we're racing from point a to point b. Little less if lightly loaded and just cruising.
BKH
Livin' the Dream
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2005 at 3:36pm
With little boats like Mustangs, it really depends on how many people are in it, because I can tell a difference when there is just a driver and a skier, but two or three extras in the boat and she'll burn alot more gas. But per hour I would say 3 maybe 4 gallons a hour, which is mostly wakeboarding/wakeskating at 19 to 20 miles per hour with only a driver in the boat. I will say the holley I use now does use more gas than the original carb.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2005 at 3:41pm
Also, diagnosing with a vacuum gauge would be very informative for a while..
You wouldn't want the PV's to be open just cruizing with a tuber or recreational 30mph skier, so sizing the PV# to keep it shut till needed, and size the mains for a good burn at lower speeds then sizing the PVCR's to 25% of the flow of the mains (50% the diameter) would likely net best economy. Holley marks their jets by flow, not diamter, so some decoding is in order.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2005 at 4:25pm
I just had a thought. Could the problem be that original prop off my '66 Mustang which I have been running all year on my '68? From readings in other posts I well know that new props out perform older props - are they also substantially more efficient?
A new prop has been in the que for me to buy all year but so far I keep finding more important things to do with $350.00. (Such as buying gasoline.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2005 at 6:04pm
What are you running, 12x12 or 12x14?
Tim D
captan1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captan1 Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2005 at 6:06pm
I have a problem, when I start my engine and look down the gas filler tube it looks like a toilet flushing.
I wonder what gas is at the dock this weekend $$. It's about $3.05 for regular at the gas stations here in California.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2005 at 6:20pm
Tim D, it's a 12 x 12.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2005 at 6:23pm
captan, you are right - we don't need a fuel pump on our engine, we just need a flush handle on our gas tank.
jameski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2005 at 6:46pm
Jim_in_Houston, I have noticed substantial gains in efficiency since I put the new ACME on a few weeks ago. It takes much less throttle to accomplish the same amount of excelleration, especially towing. I never would have thought it would be enough of a fuel savings to justify the price of the new prop, but with THESE fuel prices...
current boat
94 Sport Nautique
previous boat
78 Martinique
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2005 at 7:13pm
I burn 6 gallons in about 20 mins if I'm wide open or above 4000 rpm. If i just put around it's not too bad
