  New Posts New Posts RSS Feed - Winterizing ?
Winterizing ?
Chrissn2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chrissn2001 Quote  Post ReplyReply Direct Link To This Post Topic: Winterizing ?
    Posted: November-13-2011 at 5:41pm
Adding antifreeze seems like a long process for me...Do I need to worry about running the engine without water or antifreeze getting through it? How much time do I have? How many rpm's should the engine be running when I'm doing this?
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2011 at 5:57pm
There are volumes already discussed on the site about winterizing, but to answer your questions-
Adding antifreeze is really easy and took my 10 year old and I about 20 minutes from start to finish to do this year. There are 2 basic methods. You can either drain the block and pour it in per owners manual in the reference section of the site. Or you can use the bucket method where you put the intake hose into a bucket full of anitfreeze and suck it up till it is coming out the exhaust. I use the bucket method because I cannot get the drain plugs out of my manifolds.
You cannot run the engine dry unless you remove the belt from the raw water pump because you will ruin the impeller.
When sucking up the antifreeze just do it at idle. If it does not draw up the anifreeze you have a bad impeller.
How much time you have depends on when it starts freezing in your area.
Use the advanced search feature and you will find tons of info on winterizing.
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chrissn2001 Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2011 at 6:09pm
Just to clarify, is the intake hose the one that leads to the strainer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: November-13-2011 at 11:26pm
Yep that is it. As the bucket approached empty I also fogged it through the carb to coat the cylinder walls. Kind of sad putting her away for the winter.
1973 Skier
