  New Posts New Posts RSS Feed - Strange carb leak after rebuild
MI-nick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Topic: Strange carb leak after rebuild
    Posted: April-25-2012 at 3:12pm
last winter I rebuilt the carb for the '88...pretty uneventful. last weekend I hauled the boat up north to put in for the summer. fired it up on the hose to check everything out and it was leaking gas from both bowls around the plugs where the external float adjustment screws would be. i was confused and perturbed and contemplating stealing the carb from the '93 so I could go wakeboarding. i decided to think about it a while and go get the pontoon. thought about it all night and decided i was going to swap carbs the next day. before heading out the pick up the '93, i fired the '88 again on the hose to see if some miracle happened over night...and wouldn't you know it...no leaks...put it in the water...no leaks...go figure. anyone ever seen anything like this?? is there some sealer around the plug that had dried out from the carb sitting empty all winter?? did the plug itself need to swell from gas fumes??
As far as I can tell, I'm not quite sure...
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2012 at 3:27pm
did some searching and the leaking doesn't seem to be too uncommon...but the leak stopping does...
Lakeview View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lakeview Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 11:34am
Your lucky-but keep an eye on the plugs-there are rubber O rings around the bottom of those plugs,and the ethanol fuel slowly eats away at them- mine was a mist shower blowing out of the plugs-new bowls solved the problem.
Lakeview
1992 Barefoot Nautique
1967 Barracuda SS
1967 Chris Craft Cavalier
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 1:22pm
some crud might got there in the float needle and seat preventing to fully close....
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 3:09pm
where did you get the new bowls from?? this boat is now kept ~4hrs drive from my house...so I may want to be prepared in case they start leaking again.
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 6:05pm
I am pretty sure skiDIM had them last year when I ordered my carb kit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 8:27pm
they have the primary, but not the secondary...and there price seems quite high compared to jeggs or summit...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 8:48pm
Even after the 10% discount?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 9:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 11:44am
i've decided to order the bowls from jegs. I want to get another needle and seat too as I still have a drip from the port side primary venturi after shut down. it may just need to be cleaned again, but I want to have a spare since the boat is 4 hrs away now. size is the question. the old seat that I took out was stamped with a "97" which i'm guessing means .097" seat size...but, I can only find .0785" and .110" sizes online...any ideas??
