  New Posts New Posts RSS Feed - Checking transmission fluid level
Tadpole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tadpole Quote  Post ReplyReply Direct Link To This Post Topic: Checking transmission fluid level
    Posted: June-28-2012 at 12:22am
What is the proper way to check transmission fluid level. Should the transmission be hot, change from forward to reverse and vice versa, or should the transmission be cool. Thanks in advance.
By the way, I have a 1993 ski nautique with a PCM transmission.
1993 Ski Nautique
Airgrabber View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Airgrabber Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2012 at 2:19pm
Transmissions should be hot motor off and they suggest checking it when the boats in water.
Life is good. Work hard! Play Hard!
