temp sender to gauge |
kapla
Posted: July-25-2012 at 6:12pm |
I need to order a new temp sender as the one I have now is kinda broken, the screw part to where the cable lead and nut bolts on spins loose.
It still reads temperature, but the other day started to read funky. I remember the protec had 2 temperature senders, one to the gauge and the other to the protec coil pack. Are these the same? I am currently using one, as I have no protec. Can I just put the gauge cable there or works with another signal? |
<a href="">1992 ski nautique
Bri892001
Nautiqueparts seems to indicate that the Protec Sender and the Gauge sender are different:
http://www.nautiqueparts.com/sendersandsensors.aspx Although, the wire connection is similar, it's just the gauge sender is fatter. Not sure if they are the same resistance calibration. You could always try connecting to the leftover protec one and see what you get. Are both on the intake manifold? |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21135 |
Nice try Kap, but I dont think it will work. One is a sender, the other is a switch.
kapla
so I will need to order one....now I´m confused on the skidim site wich one will be the correct one...I´m buying parts there to rebuilt de RWP, so I want to also order this...
kapla
got it right! thanks Tim and Brian!
fortunately is that one, the switch go for $36! |
