  New Posts New Posts RSS Feed - Ethanol gas
Ethanol gas
rbbordner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbbordner Quote  Post ReplyReply Direct Link To This Post Topic: Ethanol gas
    Posted: October-12-2012 at 4:09am
I have been running 92 octane 10% ethanol all summer and I probably have a 80% full tank. I was under the impression less than 10% ethanol was ok. As I prepare for the winter I am wondering what I should do. Due to local wild fires and a bad back I haven't fired her up in about five weeks. I did find a local station where I can get ethanol free gas moving forward. Advice? From reading it sounds like problems arise when the gas sits.
RB
1993 Ski Nautique
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2012 at 4:20am
A lot of guys add a stabilizer to every tank. Certainly it should be used before storage. I run the non-ethanol exclusively. I have seen what corn does to my poop, and I am convinced it does not belong in the skinautiques gas tank.
1987 Ski Nautique
snipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snipe Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2012 at 10:08am
I too use NON ETHANOL gas only. When I put the boat away for the winter I add Sea-foam,Marvel Mystery oil, and stabilizer. I leave whatever gas is in there and mix proportionately. In the spring I hit the key and it will fire right up. My tank is made of aluminum and I have yet to experience a problem. In a former boat the tank was stainless steel and was not run for six seasons. That boat also fired right up. Bottom line.... I don't get too carried away with "Drain or Not".
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2012 at 11:56am
Hahahahaha.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbbordner Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2012 at 5:54pm
Walmart had a product called Sta-bil ethanol treatment for use with each fill up. Called it a marine formula. Is this what I want?
RB
1993 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2012 at 6:34pm
[QUOTE=snipe] I too use NON ETHANOL gas only QUOTE]
Unfortunately alot of us don't have that option
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2012 at 8:21pm
Egon and I only need to drive about 5 miles to get it up north!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote snipe Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2012 at 8:48pm
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2012 at 10:01pm
Put some stabilizer in the tank and run the boat. You want some of that mixture to reach the injectors.
Tim D
gsyogi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsyogi Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2012 at 9:31pm
So, I am a new '94 SN owner and am trying to understand this ethanol issue ... I live in a major metro area (Denver, CO) and non-ethanol is hard to come by. I ran our new boat (new to us) for approx. 20 hours this summer on fuel containing ethanol!? I filled the boat up with "premium"/93 octane and had the dealer add a stabilizer (this is part of their standard "complete" winterization) prior to putting the boat away for the winter. Can I get some guidance on what I should do with each tank going forward? Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2012 at 10:00pm
Brian,
Run the ethanol but there is no need to go with the high octane. Follow what octane is needed per your engine manual. The stabilizer for storage is needed. The ethanol fuels have a tendency to separate into gas/water layers.
malibud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote malibud Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2012 at 11:02pm
i have heard there is more ethonal in premium it adds octane not sure if it is true
79SNbrady View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79SNbrady Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2012 at 12:20am
I beleave it does add octane. E-85 is basically street legal race gas, playing with turbo imports we would run a lot bigger injectors to run E85 and get dyno tuned. The barrier on 93 octane is around 500ish hp safely, but E85 will make the same power as C16 race gas.
Since are old boats dont have fiberglass fuel tanks there is no worry. I havent had to rebuild a carb in my boat since Ethonal has been widely used. I prefer it over regular gas, ive tossed the idea around of going to a much bigger carb to run E85 after my rebuild/ mild build
Use fuel stablizer at the end of the season and you will be ok. Boat us magazine said to store a boat with a full tank of gas rather than a half empty tank, i forget the reasons why off the top of my head right now.
"It's just water... not concrete or dirt... so just throw it"
-Parks Bonifay
1979 Ski Nautique - (stringer job completed summer 2012)
2007 236 Team - All White!
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2012 at 12:45am
I think it's not just the tank to worry about; I recently saw a number of cut cross-sections of replaced badly-degraded fuel lines from fairly new boats (or at least "new" from my perspective), from ethanol use. Amazing degradation, wich I'd taken some photos. Non-ethanol is available at two marinas on Oconee and so I feel quite lucky; I've got enough to worry about with 75 years worth of old boats without having to cope with the downside of "environmentally-friendly" " gas issues....
My favorite Dinosaurs were carnivores, and so are my boats. And so, I feed them a strict corn-free diet...
1974 Southwind 18
1975 Century Mark II
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79SNbrady Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2012 at 1:53pm
From what I've read, the main issue is that ethonal gas would cause a release of resin in fiberglass fuel tanks an did major damage to engines.
The performance capabilities of corn gas is awesome, pump gas is very sensitive to spark knock (detonation) were as corn gas is very forgiving and allows gobs of aggressive timing that pump gas only dreams of. When I finally upgrade to a fuel injected 210 sante I'm definitely going to use a aem ems and going to get dyno tuned for corn gas just not sure if I wanna get tuned on e85 or 93 with 10%. The down side to e85 is roughly 20% loss in gas mileage, but e85 is cheaper. I know I'm against the grain of the ethonal fuel debate but I sure do love me some corn power
-Parks Bonifay
Randy_in_Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2012 at 5:11pm
For anyone interested in finding Ethanol-Free gas in their area check out this site:
http://pure-gas.org/
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2012 at 6:01pm
That Pure Gas list is old, I know the marina on the other end of my lake hasn't had ethanol free gas for a few years.
The problem with E85 and ethanol in general is that it attracts water and that just doesn't burn very well even if all the lines are good and there's nothing in the tank to gum up the system.   I can run E85 in my truck, but i rarely makes financial sense to do so because the MPG drop eats up any savings on the fuel and not to mention all the extra trips to a special station to get it. I've also noticed that there seem to have been quite a few more boats on fire posts this year, and I'm wondering if maybe the ethanol is degrading the fuel lines and may be some of the cause for this.
I does make for cheap race gas, but these aren't the boats to take to the lake if you're looking for a race.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2012 at 8:32pm
I think key factor cars vs. boats is frequency of use. Cars are in use/in motion daily and fuel cycles thru regularly without time to sit/separate/degrade (plus they're compatible with ethanol anyway)
CCFans use boats more than the average boater. But I'm sure overall average boat use is surprisingly low. Staff at my marina says most of the other boats go out a couple times a month, some rarely at all. As we painfully know, lotsa factors can get in the way of boating (time, money, work, family, plans, weather, etc)
So...if you have a 30 weekend boating season (and don't live on the water)and are lucky enough to go out once per weekend thats still only 30 uses/year. That's 335 days for ethanol fuel to just sit there and do its evil work...
1974 Southwind 18
AAM196 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2012 at 1:28pm
Damn ethanol!
I add Sta-bil marine to every tank and always fill up before I park her for added measure. I've read a few theorys about why to fill tank before storing... the correct is that it reduces the chance of fluctuating temperatures adding condensation to the fuel. I double up sta-bil (1 once to 5 gallons) for last fill before storing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2012 at 10:18am
We northerners don't get 30 weekend seasons, I stretch it and 26 would be a long season, 20 is more like it for most people. Must be nice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2012 at 9:22pm
I have mentioned it before but I have NEVER had a problem with the ethanol gas! Yes, I will run a tank of non a season, have always used a treatment for storage and filled the tank for winter at least 90% full but that's it.
Now that I have mentioned it, watch I'll have nothing but problems next spring!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2012 at 11:06pm
Yup, but mid-summer can be pretty hot around here. I'd sacrifice a few weekends in trade for some of that cooler NH summer air
1974 Southwind 18
Munday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Munday Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2012 at 11:08pm
I think ethetol is hard on (old)soft parts. I also think stabil helps preserve soft parts under these conditions. So far I,ve been able to run 100% gasoline in boats, tractors, and bikes.
Bob
If the only tool you have is a hammer,everything starts to look like a nail.
