Pylon removal turns into restring |
Post Reply | Page 123 6> |
Author | ||
forvicjr
Gold Member Joined: August-24-2012 Location: sc Status: Offline Points: 692 |
Posted: October-23-2012 at 6:10pm |
Ok, before I ask I want everyone to know my question has been searched with no real answer. Im trying to remove my pylon from a 81 tique. The four vertical stainless bolts have been removed and the lower reinforcing plate is free. I moved down to the lower horizontal bolt and discovered it was missing. At this point the pylon is still concrete tight. I then drilled through the empty bolt hole to clean it out. I was thinking it was rusted away an some of the bolt was still there holing it. I then flooded it with PB blaster and let it sit. Hours later I came back with a pipe wrench(a big one) and locked on to it between the floor and the hull. I think If I put any more pressure on this thing I will twist the lower mount out of the hull. I have also hooked an engine hoist to it and applied carefull upward pressure while trying to twist and or shock it loose with a hammer. After all this theres not even a hint of movement. Any suggestions?
“Tact is the ability to step on a man's toes without messing up the shine on his shoes.” ― Harry S. Truman
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21136 |
Most pylons Ive seen with the welded flange and 4-bolts through the floor didnt have the additional bolt through the hull cup. The purpose of that bolt is to keep the pylon from spinning, which is more likely to happen on a cradled boat that clamps the pylon in place rather than bolts it in place to the floor. Probably a universal hull cup being used in '81, as the SN's got the cradle starting in '80. No need for that bolt on your boat.
To get your pylon out, I suggest getting a breaker bar and put it through the ring of the pylon. Surround the ring with a towel so as not to damage it. Go nice and easy... start by rotating the pylon around to break it free, then slowly start working it up (rotating at the same time). I got a stuck pylon out of a '79 Mustang using this technique a few weeks ago. |
The pin on the bottom of the pylon is rusted into the socket glassed in the hull. Get some decent penetrating oil on it like Kroil or a 50/50 mix of acetone and ATF.
That will only get you so far! The pylon I helped pull had been sitting with penetrating oil on that joint for several weeks. Still took a bar to get it to budge. Probably not a bad idea to do first regardless, though. |
forvicjr
Man, Im scared as hell to try to move this thing with the ring and finger,I didnt measure it but Im a stout fella,I know I aplied over 200lbs of twisting force to the lower part of the pylon(two foot pipe wrench with a cheater).Ill do the home brew penetrating oil thing.Anyone else want to add to this,I'm all ears. Thanks guys |
cbr1000dude
Senior Member Joined: August-23-2011 Status: Offline Points: 330 |
My son in law removed the pylon from the 87 SN. 200 lbs won't do it, you need leverage. The ring had been hacked off by a PO. After soaking a few days with penetrating oil, he used a 24 inch long pipe wrench near the bottom with a four foot pipe over the end with 2 guys pulling on it. Even at that, they had to work it back and forth a few times. It left marks, but they'll sand out. My trailer guides on my 90 SN needed the same set up to unscrew. It'll either break something or come out I thought, either way it had to come out.
I saw a guy remove a rusted 400 FP torqued bolt with a 8 foot pipe extension and a big pipe wrench once. Give me a lever long enough and a place to stand, and I'll move the world. Archimedes |
A professional would be using a torque multiplier. It's a common add on to the ratchet and designed for multiplying torque. You have been watching too many back yard hackers with cheater pipes on the end of wrenches not designed for the torque. DO NOT COPY THE BACK YARD HACKER METHODS. |
cbr1000dude
Thanks for the professional advice. I never heard of a torque multiplier. I'll look that up. I don't see how a ratchet would help with a pylon however but I'm sure you'll tell us.
No, on a pylon it won't unless you came up a decent way to connect the wrench to the actual pylon.
The big multipliers are 100 to 1 so that means if you put 80 ft. lbs in, you get 8000 out. |
forvicjr
Heres what what im working with. Tried again just now, still not moving. Got the boat on the lift, it is level. If I break the pylon mount, that will be the string that breaks the camels back on the stringer job. |
ny_nautique
Platinum Member Joined: June-01-2011 Location: Albany NY Status: Offline Points: 1215 |
Sweet lift setup! What is the first pic showing? Is that the bottom in the "cup" made of glass?
My 84 was tough to get out but a pry bar through the ring like Tim described worked. My pylon was already gouged up though because the PO had a barefoot boom attached to it with nothing to protect it. |
- Jeff
1999 Ski Nautique |
forvicjr
Ok. Peter we rollin with the stringer job, figured you would like knowing. The rest of you please help, Im in uncharted waters here.lol The reason is the pylon cup mount is trying to break free, so I guess the whole floor and stingers is coming out.
Air206
Sad to see the mess under there....gonna look better and better and better.....
forvicjr
Im leaving about a 1.5 inch of fiberglass around the edges of the boat for reference, from what I've read here this stays until all stringers are set. Right? Got almost all the floor and foam up tonight. The starboard stringers look like they will be good to replicate from. Port side is all mush. As I thought though the mains were pretty much still there.But Pete there coming out too,along with all the transome wood.
Till tomm, I should have everything out by the end of the week. Yeuuup!! I sure do trust my lift. |
connorssons
Platinum Member Joined: January-17-2009 Location: Michigan Status: Offline Points: 1414 |
the next purchase for my barn, a good lift
forvicjr
I really like my lift. It turns my two stall shop into three. Getting the boat on the lift was a little rough because the trailer hindered getting under the boat. I had to raise the arms and lift it with straps then pull the trailer,after that I had to lower it down on supports unstrap, lower lift and then relift from the hull.The stands I still use,when I got to work on it I lower it down to the stands on marked spots on the floor and its instantly level.Just have to make sure all epoxy work is set up before relifting to assure a good bond ond one that will stay where I put it. |
forvicjr
Hey guys, I've been searching for doug fir all day today out to a fifty mile radius. The only fir I can find has a moisture content of at least ten percent. Will this be ok? Is there a way I can further drop the moisture content?
SNobsessed
Pete will certainly comment on the moisture - Possibly you can tent the wood with a dehumidifier for a while.
You will want to support the hull very well before pulling the main stringers, otherwise it could oil can & you could glass in an uneven 'hook' with the new stringers. |
forvicjr
The lift is for storage purposes, while replacing and bonding stingers it will be on level stands set up at hull edges directly under windshield and at transom. It will stay on stands till all is bonded and dry. This is acceptable? Oil canning?
I read that stringers shouldn't be done on the trailer true? |
Ideally you will want to get the moisture down to 8%. Sticker and band and then run a heater and dehumidifier. I like Chris's idea of a tent but a small dry room would work as well.
Some have done stringers with the hull on the trailer. I don't see a problem with it. If you do get some oil canning, a few extra stands should take care of it. The alternate to the Doug Fir and staying with wood, is LVL. "Big Papa" used it and documented his job. |
turningpoint84
Platinum Member Joined: September-11-2008 Location: Cincinnati, OH Status: Offline Points: 1467 |
Could go with a composite job too, it's $$$$, but my thought is if you're going to spend the time, why not go with composite stringers? Wouldn't they "last forever" too?
Proud 1968 mustang owner and now
1970 Mustang |
Peter no matter which way you were to do it, I don't think there is anyone out there who after going thru all that work, would put it thru the abuse that they took before we bought them.
JoeinNY
That would be me- my 83 has had a much harder life in every way I can think of except dock rash in the five years I owned it after a rebuild than in the 24 or so before that. Further, I wouldnt consider the life it led for the first 24 years to be abuse, it had less than 400 hours and was used lightly enough that the original astroturf was very close to new condition, and the painted stripes and decals were all in good enough shape the boat almost certainly didnt spend as much time out on a lift as it does under my care. |
turningpoint84
While I agree, we both know they'll eventually rot out again, IDK i figure if you're going to spend $1500 + 100HRS why not spend $2200 and +100hrs. I obviously don't have much room to speak as I've never done a stringer job, but i do know, my 1970 is due and will be done one in the next 5 years. I'm not looking forward to it one bit, but after reading JoyinNY's thread on his 83', i just can't see myself going any other way. He pretty much gave us all a free "composite stringer job for dummies" book. My other issue is this also, you guys are telling him to get a space heater, tent and dehumidifier and sit the wood in a tent for however long, it's just more time and effort put into wood stringers, that might not come out to the 8% he needs. |
1970 Mustang |
forvicjr
The way I look at it is the wood stringers in my boat lasted 31 years and wasnt a total rot out. When I replace them according to most here the rework will be better than new. In that case they ought to last longer being done better and the boat not being used as much(in my case). Im 34 and in thirty one years Ill be 65, I dont think I'm going to be worrying about boat stringers at that age. Hopefully I'll be O D ing on viagra and playing on the bank.Lol...
forvicjr
On another note, I have found out there is a fiberglass boat manufacturing plant down the road from me. It's not a real big outfit but maybe I can go get some intelligence on stringer work from them also. Might also be able to purchase some supplys also.
turningpoint84
That's pretty awesome, I'do this route. |
1970 Mustang |
I don't agree,you would use better wood,cpes and epoxy, things the factory never did. And by abuse I mean storing outside not covered or with a poor cover,letting it sit in the water when not in use,something like how mine was taken care of. |
Lakeview
Senior Member Joined: January-06-2004 Location: Branchville NJ Status: Offline Points: 247 |
Try tapping around the pylon base with a ballpein hammer-it worked freeing up the pylon on my '85 SN-just keep spraying,twisting and tapping-it will come out.
Lakeview
1992 Barefoot Nautique 1967 Barracuda SS 1967 Chris Craft Cavalier |
turningpoint84
Gary, I understand, i think it's more of how we plan to use our boats. I for one have always been a drop the thing in the water and expect it to float for the next month, until i pull it out for winter storage. While it will always be stored inside, i just feel that i'm more susceptible to rot, really it's just how each owner plans to use it. Like JoeinNY, smart go to composite. |
1970 Mustang |
