  New Posts New Posts RSS Feed - Battery type/size
Battery type/size
LAKESIDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LAKESIDE Quote  Post ReplyReply Direct Link To This Post Topic: Battery type/size
    Posted: February-09-2013 at 12:25am
Wondering if anyone with a 93 SN closed bow has bought a cranking battery lately? Been searching around for correct size. Maybe a battery model #? Thanks in advance. Ready to get back up and running.
93 Ski Nautique   SUCK MY WAKE
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 11:04am
Group 65
jimsport93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimsport93 Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 11:14am
Dave, the owner's manual for my 93 Sport states the following:
Engine size 351, cold crank 380 amp, reserve capacity 115, battery type 43 marine, 13"L x 8"H x 6 3/4"W.
The battery on my Sport is located under the middle stern seat base. Would think is would be the same on the SN.
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 12:54pm
I have a 1993 SN closed bow, and a group 65 battery fits snugly into the box. I got one with 880 cold crank amps. 380 is a minimum. It looks like you know not to get a deep-cycle battery already. I told the guy at a Batteries Plus place up here that I was looking for a battery for a muscle car with a 351 Ford V-8 and wanted a group 65 size battery. I got exactly what I needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimsport93 Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 2:15pm
Kevin, bought my boat back in June of '07. PO put a Sears Die Hard that is a little too big. Sits at a slight angle in my battery box in the stern. Have used that battery for the last six summers with no problem.
Figure it is getting about time to replace it. Yes, I know not to get a deep cycle (no trolling motor on my Sport!). Will be looking for a group 65 when the time comes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 3:22pm
Hi, Jim. I looked through the owners manual for my 1993 Ski and all it says is a minimum of 350 CCA's. It also mentions that more information is located in a sticker on the underneath side of the lid that goes over the battery box. In the Ski the battery is located up front under the observers seat.
I don't want to jack a thread, but in the box are two plastic tie-down pieces that accept a strap used to hold down the battery. I don't have these plastic parts nor the tie down strap. Anybody have an idea where I could buy replacement parts for my battery compartment?
Kevin
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 3:40pm
Kevin
Kevin,
You should be able to find webbing and buckles to match at the hardware or home improvement store.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 3:48pm
Thanks, Pete.
I also answered my own question as I did some more online research today and in 5 minutes I found this:
Amazon battery kit for under $8
Post Options Post Options   Thanks (0) Thanks(0)   Quote LAKESIDE Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 5:59pm
Thanks guys. I also know to get a regular battery not deep cycle. I already have one of those running my sound system. Separate from starting system. And i found this after some searching from Wally world. Looks decent enough. EverStart Maxx 65S
Also on the straps try a upholstery shop or marine canvas shop we keep those in stock. There cheap also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 6:09pm
Thanks, Pete.
Kevin,
That kit will do the job but just be careful of how deep those screws go. It may have been before you joined but we did have a member who wanted to drain his battery box into the bilge. What he didn't realize was the bottom of his box was the hull. Yup, he drilled and then hear water running onto his garage floor!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 6:15pm
Dave,
Just be careful with getting the largest CCA available in a given group size. Plate support is sacrificed for plate area for the amps. This makes the battery suspect to damage from the rough conditions in a small boat. Years ago, I made the mistake twice before I found out what they do inside to get the amps. If the CCA isn't needed, don't get the big one. I suggest one step lower in CCA for the group size needed.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 9:52pm
Not sure what the difference is between the 65s and 65n is, but I run the latter ever start max in nearly every boat I own. Good choice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 10:23pm
From the Everstart website:
"The N & S designation means North and South. South are designed to withstand extreme heat & North the cold."
Still, doesn't really explain anything!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2013 at 11:52pm
Going on to 2013 with the original battery from a 2000 Lincoln cranking a PCM 302
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2013 at 3:09am
Thanks, Pete.
Kevin,
Oh no! That would be a real oops. Ha ha.
I narrowed in on this kit because it replaces exactly what is in a 1993. See the black plastic piece in the battery box on the right in this photo (this was taken as part of my floor repair project)? You can't tell here but that piece is broken, and on the other side it was completely missing. So I'd be attaching the replacement parts into the side of the box not towards the bottom. And a 1993 battery box already drains into the bilge.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2013 at 9:52am
My 88 has a drain, but it wasn't going to the bilge.
Now it has bulkhead fittings and clamps.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2013 at 11:24am
Has anyone ever had a battery jump out of the box? With the cover on?
I haven't been tying my battery down at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2013 at 11:33am
No and I don't have anything holding down the batteries in any of my boats. However, there are some USCG regs on enclosing and retaining batteries.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2013 at 11:39am
I don't remember what group battery I have, but it is several inches shorter than the box.   I have some plastic blocks next to it to keep it from sliding around.
