Flame Arrestor |
62 wood
Posted: February-09-2013 at 4:51pm |
I'm looking for an arrestor to fit a Q'jet. Wanting to replace the damaged one on my 73.
cphase
Gold Member Joined: May-11-2010 Location: Newnan, GA Status: Offline Points: 795 |
62 wood
Thanks jeff, but I'm trying to keep any mfg name off it (unless Thermo Electron , or maybe Crusader)
Probably being a bit "petty". Actually I would love DrCC's brass one , but dont think it will fit the carb. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21131 |
Looks like a standard 5" throat on that quadrajet. Same as all the Holley 4160's that most run. Al's arrestor would have to be oddball not to fit (dominator, etc).
I've got a few better looking ones than that zenith (ss or brass) if you don't end up grabbing al's. |
62 wood
Tim,
I dont think Al's will fit. I tried a similar one from one of my 'cudas and the arrestor is too thick to fit between the inner carb flange lip and the casting boss for the accelerator pump lever. the Zenith has a thin, sheet metal flange. I would love to find something with more "bling" than the Zenith. Does either your ss or brass one have this type of flange? Also anything taller would give me clearance issues. |
Got a picture of that carb so I can see what you're up against?
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
62 wood
Bruce, That's nice. Looks like one with 2" high element is 3" overall ht. Wonder if there are pics of the bottom? Here are a couple of carb pics.. This is the "problem" flange area.. It wont let this style brass arrestor seat... I suppose I could do a little "carving" of the carb casting ... might let it drop? . |
DrCC
Does it clear the fin in front of the vent tube?
DrCC
1 Dremel and a tube of Flitz....wah-lah!
Riley
It's got a decent size lip. I can measure it and take a pic of the bottom.
oldcuda
Senior Member Joined: June-22-2010 Status: Offline Points: 474 |
I have got one off Merc BBC w/quadrajet believe it is the same one.I will go get it and send a pic.
62 wood
I just won two aluminum arrestors off ebay last night. Will see how these work and go from there. Thanks! |
john b
Grand Poobah Joined: July-06-2011 Location: lake Sweeny Status: Offline Points: 3238 |
Bruce, What make are the manifolds on that engine? They look great and I have been looking for a set of logs for my 302. |
1970 Mustang "Theseus' paradox"
If everyone else is doing it, you're too late! |
Riley
John, those are the standard logs Interceptor used on their 352,390 and 427 engines for most of the 60's. They later changed to rectangular manifolds. This picture is of a small block Ford Interceptor with the only logs I've ever seen them use on the SBF. I've seen them on ebay occationaly.
