Need Advice - Experiencing high torque (RPM) probl |
sandro.zaal
Groupie Joined: October-08-2012 Location: Tbilisi,Georgia Status: Offline Points: 64 |
Posted: March-13-2013 at 10:56am |
Hi
Im Experiencing high torque (RPM) problems with PCM 351 Pro Boss 1994 GAS. When the engine starts, the RPM goes to 1500-1800 RPM and goes down very slowly back to 1000-900 RPM. I need to wait a minute or even more to shift the gear. Sometimes I have to switch the engine off, because, it never calms down. I dont want to make some problems to gearbox. If you know what can be a problem please let me know. Thanks |
SNobsessed
It could be a vacuum leak, EI timing, or a fault in the fuel injection system.
I would 1st narrow it down to one of those things. To test for vacuum, spray carb cleaner around all manifold gaskets & vacuum line connections, while engine is running. Engine will change RPM if you find a leak. Also use a timing light to see what EI is doing. I can't help on the Fuel Inj, other than to suggest checking pressure at the fuel rail. Good luck. |
quinner
Do you have perfect pass?
Would start by checking the throttle cable, be sure it is not under pressure against the shroud, a hose, etc. If a Pro-Tech motor, could also be the issue |
sandro.zaal
Thanks guys. No I dont have Perfect Pass. And engine is Pro Tech Injection.
quinner
94' Pro Boss with EFI & Pro-Tech
Does this only happen after the motor get's hot, after some ski runs?? |
sandro.zaal
Yes. Sometimes it works just fine. But, mostly not. I know the idle RPM must be around 600, but it never comes below 1000.
