2000 SN Impeller Change |
peteb
Newbie Joined: March-24-2013 Location: Cincinnati, OH Status: Offline Points: 7 |
Posted: March-24-2013 at 9:50pm |
Does anyone have a 2000 SN where changing the impeller is difficult since the cover bottom screw is tight up against the floor carpet. Need to see if there are some tricks before I de winterized the boat in a few weeks. Bought the boat over the winter and see it looks like an issue. Will post pics once I figure out how.
2003 Sport N 216
2000 Skier 1990 SKier |
lewy2001
Pete just replied to your thread over on PN. I think you have the Chev 350 based Apex engine as from memory they have a crank driven RAW water pump. Indmar also use this type of crankshaft driven pump.
If you are unable to remove the impeller as it contacts the floor. I would be tempted to put a small cutout in the floor so you can. I do not think you have much other choice than lifting the front of the engine every time you want to change the impeller. |
Pull the RWP off it's bracket?
lewy2001
Gee Pete sometimes we miss the obvious.
