Holley Carb Question |
Twothousandone
Groupie Joined: July-10-2012 Location: Pittsburgh Status: Offline Points: 54 |
Posted: April-14-2013 at 4:28pm |
Just bought a used Holley carb on eBay. It came off a nautique with a 351w engine. It has adjustable float bowls and looks very similar to mine other than the float bowls. My question is...my fuel inlet is a screw on brass fuel fitting. The one I ordered on eBay looks to have an inlet you clamp a rubber hose onto. What will I have to do to get this to work?
cphase
Gold Member Joined: May-11-2010 Location: Newnan, GA Status: Offline Points: 795 |
Tyler, can you post some pictures, doesn't sound like a marine carb. Should not have external float adjustments and the fuel inlet should be side hung on the primary bowl and except a hard fuel line. It should not have a hose barb.
Tyler,
I agree that the carb may not be a marine version. Jeff is correct it should not have external float adjustment and it should have a flare adapter for the fuel hard line (steel). Why did you buy it anyway? Why not just rebuild the one you have? Hopefully you didn't spend too much $$$ on it!!!! It most likely is scrap metal. Just because the seller said it came off a Nautique doesn't mean he isn't an idiot. You should have asked us first!! |
cphase
Here is an image of a marine 4160. Hope this helps.
Twothousandone
I paid 66 for it shipped,comes with a rebuild kit, all kinds of fittings and parts, spare power valves, and also driveshaft packing oddly enough. So for parts its a super good deal. I guess it possibly may have been a car carb converted for marine use. It has J vent tubes in it. I rebuilt my carb last year but was having problems still. Even after I kill the engine fuel still drips into the manifold and causes a flooding situation. I replaced and bent the tang numerous times on the primary bowl, but the situation is still the same. Was going to try this one for test pretty much. I'll post picks when I get it. Thanks guys
SNobsessed
FYI, we have had reports of bad needle/seats in kits. So the problem you had last year may not be the carb's fault.
I think the Daytona kit is highly rated. |
cphase
Here is the link to Daytona Parts, I like their kits.
Twothousandone
Thanks guys, maybe I'll just pop a new needle and seat in and see what happens.
I second the Daytona Parts kits. Their needle and seat design is the best.
