Gel coat ghosting |
Author | ||
skitique179
Senior Member Joined: December-06-2011 Status: Offline Points: 176 |
Posted: April-24-2013 at 11:48pm |
Hey guys,
I have a 1982 ski Tique that has had the original graphics removed sometime in the past. The gel is in relatively good condition however if you look closely there is some ghosting from the original graphics. I know there have been some posts about this in the past but what is the least painless option for removing this? Thanks |
skitique179
I know you guys like pictures so here is what we are working with...
skitique179
skitique179
SNobsessed
I think the best way to eliminate the ghosting contrast is to put the graphics back on. I have heard that even wet sanding doesn't hide the color shift.
skitique179
Is there a source for ordering vinyl graphics for this old of a correct craft or do most people paint them on?
Bones71
Senior Member Joined: March-09-2013 Location: Bettendorf Ia Status: Offline Points: 334 |
I am ordering graphics from Zachary at N3 boat works for a 89 SN. Bones.
Bones71
I mean Zach not Zachary damn spellcheck.
SNobsessed
The early '80s & older were painted on. However, some guys here have a CAD file of the mask that can be used to generate correct font size.
Stay tuned. |
TX Foilhead
Wetsanding works, it's just a pain because you have to start lite and polish then look to see if it worked. If it didn't you do it again starting with coarser paper and you keep repeating the process until it works.
GlassSeeker
Grand Poobah Joined: November-26-2008 Location: Elk Grove, CA. Status: Offline Points: 2421 |
I've got a 42 inch screen and I can't see any ghosting in your pics. No one will notice. Go wakeboarding.
This is the life
quinner
Stencil is there, just paint over the ghosting and it's back to original kool!
I question this. I had to regel the transom on my Tique due to ghosting from the PO's naming the boat. |
TX Foilhead
Could paint be the difference? I had no issues with stickers that were 18 years old just took 3 or 4 attempts to get it done. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21135 |
Sometimes the color fade goes all the way through the thickness of the gel. In those cases, you'll never wetsand through the ghosting. Some colors fade easier than others, and of course, the amount of time the gel has been exposed to the sun is also a factor.
I do not believe any stencils exist for an early 80's Ski Tique. The only ones I am aware of are the 80-81 Ski Nautique graphics that Alan made. Getting the mask made for the Ski Tique lettering would be the biggest challenge, but the stripes can be masked off by hand if you can see where they belong. I would repaint them, as original. |
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1412 |
I have often wondered if you could take a picture of the side of a correct graphic/stripe ( this case a Ski Tique ) make it into a slide and then project it onto the boat hull adjusting the size by the lenses and distance from the hull......giving you the outline to mask off too.....this is how they used to do it in the sign shop when I was an apprentice....... in a time before PC’s or Cell.
Lets have a go
56 Starflite 77 SN 78 SN 80 BFN |
