hull blisters |
silver#24
Newbie Joined: May-06-2013 Location: Gananna, Ohio Status: Offline Points: 6 |
Posted: May-06-2013 at 7:42pm |
i just purchased an 86 silver nautique and am having a boat shop rebuild for me. it has a few hull blisters and the shop wants to fill the couple that are visible on the side of the hull and open any new ones on the bottom hull and paint with bottom paint up to the water line. what say you?
mark c
Gold Member Joined: May-09-2012 Location: Massachusetts Status: Offline Points: 534 |
Fill with hull coloer gelcoat. No bottom paint ever.
NO BOTTOM PAINT!!! You must have taken the boat to a real back yard hack shop!!
silver#24
Ok no bottom paint. I was not fond of the idea myself. Mark when you mention gelcoat do you have a particular product in mind? I have watched a few YouTube videos on blisters and came away depressed. I am not ready to strip the hull, however I have not seen the hull cleaned yet. I am hoping not to see too many. Have any of you experienced this.
mark c
I have a gallon of colored gel coat to match my hull(hopefully)that I bought to fix some bow rash. I only needed maybe a quart but it only comes in gallon containers. Maybe this weekend I will mix up a small batch and try to fill my blisters that I opened up (accidentally with my power washer) with the gel. Haven't figured out exactly how yet, maybe a syringe without a needle to push it in, then hope it stays inplace long enough to set and then sand it down smooth once it sets up completely. I'll take pictures before and after.
ST79
Groupie Joined: December-31-2012 Location: Birmingham Al. Status: Offline Points: 98 |
You need to open the blisters up and let them dry they say you need desert heat for a couple of days but a heat lamp will work. Then you need to fill with a epoxy let dry and then gelcoat
mark c
Gel won't stick to epoxy, without a poly primer. The old boats like mine (87) used polyester resins in the glass, and polyester based Gelcoats. Maybe later in production CC changed over to epoxy.
ST79
I know from my bigger boat that the blisters are going have to be opened up and let dry and treated with something or they will come back gelcoat want keep the blisters from coming back. Normally blisters come from the boat sitting in the water for prolonged times
mark c
In my case the blisters on my boat are just 1/16" to 3/16" pockmarks where the gel literally popped off the fiberglass laminate below it. In some cases they don't actually go all the way to the laminate. I assume they are caused by one of the POs keeping it in the water most of the summer. The side that I think was facing the sun (just by looking at the condition of the two sides in general) has more than the side that was in the shade.
mark c
Can you thicken gel coat, like resin with microballons, or something similar, without affecting its final polishing to get it to fill the chips without running?
Mark with those small sizes your talking about it should cling with out filling. It will sit there much like a water drip will sit,even better because it's thicker than water.If it gives you too much trouble put a piece of masking tape over it
mark c
Well we'll see what kind of a mess I can make this weekend filling holes, as long as the weather cooperates. We'll also see how well I matched the gel using a stock color. I'm trying the V100 chip, its a lot closer in real life than in the picture.
Jadewin
Newbie Joined: June-03-2013 Location: New York Status: Offline Points: 1 |
Dies ist, was ich interessiert bin in.Welcome mir contace. __________________________________________________ Wow Gold Kaufen|Diablo 3 Gold|Diablo 3 Gold Kaufen|Guild Wars 2 Gold |
mark c
Just to keep people up on colr matching, the V100 from fibreglast is still to light to match the Taffy ivory, as is the X122 just below it on the same card (half of it is visible to the left of V100 in the image above). The X122 is closer, and actually looks good until you sand it down and buff it out, and then it becomes noticable. Probably good enough for areas on the bottom of the hull but its noticable on the deck. Now I'm trying to darken it up with a little bit of brown tint, my first attempt of adding one tiny drop of brown to 4 Oz of X122 was close, but still not good enough for me.
