Testing the EI igniter |
wsavini ![]() Senior Member ![]() Joined: September-06-2012 Location: Taunton, Ma. Status: Offline Points: 282 |
![]() ![]() ![]() ![]() ![]() Posted: July-11-2013 at 1:17pm |
Does anyone no if the igniter that comes with the EI kit can be tested to see if its defective? With a meter or something? Thanks, Wayne
Dan in CT ![]() Groupie ![]() Joined: November-12-2012 Location: East Hampton, C Status: Offline Points: 77 |
If you are talking about the coil, check ohms across the + and -. Set meter to the 20 ohms scale or something close. You should read the same resistance that is indicated by coil's manufacturer. I have a flame thrower II which is a 0.6 ohm coil.
