  New Posts New Posts RSS Feed - Stewart Warner Temperature Sender
rmcdonald View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmcdonald Quote  Post ReplyReply Direct Link To This Post Topic: Stewart Warner Temperature Sender
    Posted: February-22-2006 at 11:31pm
Hi All
I need to find what the part number is for a Stewart Warner Temperature Sender.
The Sender needs to match a Stewart Warner Temperature Gauge that has a temperature Range from
60F to 240F
If anyone has this gauge in their boat could you please check the part number on your sender for me?
Regards
Rob McDonald
Morto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morto Quote  Post ReplyReply Direct Link To This Post Posted: February-23-2006 at 3:14am
Mate, I dare say that the original sender will work. I think the instructions quote a range of resistance which is compat*table with your gauge. For arguments sake I have just installed a new fuel tank sender and the old gauge works fine (it's over 20 years old) although I did pull the needle off and tweak it slightly before sealing it all up again, so I didn't need the new gauge which looked out of place. If you're keen you can immerse the sender in a pot on the stove and note the temp when it boils (100 celcius equals 212 farenheit, and you'll need to hook up the gauge to all its wires - sender to gauge, +ve and -ve to a 12 volt source and presumably also ground the body of the sender to the -ve. Go to Dick Smith and get a packet of little jumper leads, they're all different colours and about a foot long. Perfect for this kind of job). That should give you some confidence. The temperature, oil pressure and fuel gauges all work on the same principle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morto Quote  Post ReplyReply Direct Link To This Post Posted: February-23-2006 at 3:17am
Slight correction, don't fully immerse it or you'll short the sender wire to the sender body (they're insulated by a fibre washer I think) and get a nonsense reading. You'll have to support it somehow. Keep a Crown Lager handy in case you scald yourself.
