  New Posts New Posts RSS Feed - GT40 Tach Signal
GT40 Tach Signal
2001SAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2001SAN Quote  Post ReplyReply Direct Link To This Post Topic: GT40 Tach Signal
    Posted: July-31-2013 at 9:35pm
Hi all,
Does the tach signal on a GT40 come from the coil? Gray wire? Have an intermittent 'spikey' tach and would like to get to the bottom of it. More irritating than anything else.
Cheers,
D.
A little knowledge is a dangerous thing...
2001 Super Air Nautique
1989 Fairline Corniche 31
www.bannrivercruises.co.uk
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2013 at 9:51pm
The "tach" signal comes from the grey wire on the coil it has a 22K ohm resistor in series that makes the signal compatible with most tach's.
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2001SAN Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2013 at 8:53am
Cheers Lewy. Thanks for confirmation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2013 at 9:07am
I would check and clean all connections. Try and confirm that it is not the tach by trying a shop tach or similar.
It could also be noise coming from the TFI ignition module.
Is yours the original tach or the Faria replacement. Have heard of a few problems with the Faria replacements jumping around and reading low.
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2001SAN Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2013 at 4:04pm
Faria,
It def jumps around at times. Maybe reads a little high according to my idle.
