intense vibrating, intermittent |
jackkloepfer
Senior Member Joined: October-28-2008 Location: United States Status: Offline Points: 152 |
Posted: August-12-2013 at 12:56pm |
I can't discribe this too accurately, as I was behind the boat when it occured.
my wife discribed it as more of a 'buzz' type of vibration. as though the rear of the boat had turned into a giant cell phone. we have had other 'wobbly' or 'wahsing machine' type of vibrations before that was due to having something stuck on the prop, but this was not like that, according to her. we were wakeboarding, everything else was normal (temp etc) after I came into the boat to observe, I had her run the boat just above idle speed while I examined the shaft spinning. I didn't see anything of concern. what are the possible issues that I could be having, here? thanks in advance. |
Bones71
Senior Member Joined: March-09-2013 Location: Bettendorf Ia Status: Offline Points: 334 |
Intermitten trans slip maybe?
That money talks, I'll not deny, I heard it once: It said 'Goodbye'
Bones71
Check your fluid level accurately.
jackkloepfer
I will give that a go. thanks. didn't consider the transmission. |
SNobsessed
Shaft packing too tight?
Bones71
I was thinking later that maybe someone might have had their feet on the doghouse and you might have hit a wave and pushed the cover into the belt pulley? I know we have done that and it feels like a phone vibrating. ??
cooperlacy
Groupie Joined: September-14-2009 Location: Cutler, IN Status: Offline Points: 60 |
I have come across two other things that manifested themselves as "false" vibrations. The first was a bad spark plug. At low speed this wasn't noticeable, but at high speed it felt exactly like shaft vibration. When I coincidentally decided to change the plugs, one of them had a loose porcelain insulator. New plug and the vibration was gone.
Another "false" vibration came one time when I hit a 10" piece of 2x4. We stopped the boat and I felt the prop and everything seemed normal. We started again and had pretty bad vibration. It turns out I hit the 2x4 just perfectly and it stuck on the front tracking fin. I pulled it off and was vibration free! Good luck. Cooper |
Is the prop seated on the shaft? Did you lap it to the shaft when you installed it?
CrazyCanuck
Senior Member Joined: July-21-2013 Location: Vancouver B.C. Status: Offline Points: 254 |
What does lap it to the shaft mean? I ask because I will at some point have to put my prop back on. tips? Thanks.
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
Proper prop installation
Also, is there play in the cutlass bearing due to wear? |
