  New Posts New Posts RSS Feed - Thermostat/Cooling Circulation
skfitz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skfitz Quote  Post ReplyReply Direct Link To This Post Topic: Thermostat/Cooling Circulation
    Posted: September-22-2013 at 2:19am
I believe this is an Escort marinization.
351W, 1975 Ski Nautique
The thermostat is not in the intake manifold, like it would be in an automotive application. It's under the small dome (labeled in the pic).
Raw water comes into the block-shaped piece beneath the thermostat dome and appears to go into the circulating pump. Then it goes thru the engine and comes out the intake manifold into the thermostat dome and out to the exhaust manifolds.
QUESTION: Anyone familiar with this circulation/thermostat set up? If so, is there a direct port between the block (under the 'stat dome) and the hoses going out to the exhaust manifolds so that the manifolds are cooled even when the thermostat is closed?
Thanks in advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2013 at 12:07pm
Shawn,
Water is always flowing out via the exhaust at the GPM rate of the RWP. The engine only bypasses what it needs when the T stat is calling. It's the basic principle of most of our marinized engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skfitz Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2013 at 12:19pm
Shawn,
Does that mean the answer to my question is "yes"? I really don't want to separate the two components of the thermostat junction to look for myself since the junction doesn't leak and a replacement gasket is unobtanium.
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2013 at 12:30pm
That is correct.
FYI, you can easily make your own gasket cut out from a sheet of gasket material that you can pick up about anywhere.
Eddie
Post Options Post Options   Thanks (0) Thanks(0)   Quote skfitz Quote  Post ReplyReply Direct Link To This Post Posted: September-22-2013 at 7:50pm
Muchas gracias, fellas!
