  New Posts New Posts RSS Feed - running rough
running rough
79AMSKIER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79AMSKIER Quote  Post ReplyReply Direct Link To This Post Topic: running rough
    Posted: March-11-2006 at 9:19am
Just started the 79 skier for the first time this year and she see starts a runs great for about 2 minutes than starts to run very rough or rich. she will idle fine but give any gas and starts to stumble badly. if i cut the motor and wait a minute it will restart and run great for about another 2 minutes. The carb,ignition module and coil were replaced last season. cap,rotor,plugs and wires were replaced today. Its a 302-4v. any help would be great, we are trying to go out of town this week.
I DRIVE SHE TANS
AWhite70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AWhite70 Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2006 at 1:25pm
Check and make sure the choke is operating properly.
Bob's2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob's2001 Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2006 at 2:04pm
Check the fuel filter. Are you running last years gas? If you didn't use gas stabilizer when you put away for the winter you may have gunked up your carb.
Bob Ed
83 2001
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2006 at 7:39am
Check intake for a leak. Spray carb cleaner etc. along the sides of the intake and see if it revs up. If not that, my 2nd guess is the power valve in the carb, if you have a holley.
Tim D
