  New Posts New Posts RSS Feed - Help-2 Stroke Outboard Motor
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Topic: Help-2 Stroke Outboard Motor
    Posted: February-07-2014 at 5:58pm
Been on the hunt for a 10-20hp outboard for our Jon Boat.
Going to look at this one this weekend, said he will start and run it for me, anything I should look for, at or check??
Even unsure what it's really worth, can get a brand new 4 stroke merc 9.9 for just over 2k??
Thanks and you guys won't make fun of me if I have a Short Shaft Johnson will you??
http://chicago.craigslist.org/wcl/boa/4317044967.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 6:08pm
Early-mid 70's vintage? We already know you have a short shaft Johnson.
I dont know much about that vintage 20hp... Joe might know if it evolved from 18hp from the late 50's. Ive had a few of the 9.9/15hp from the 80's that are easy to work on, reliable and easy to find parts for. Strong performers too. The same design was used '74-92 on those. Eric has a few of the mid-late 50's 15hp Johnnyrudes and those are really nice as well.
How big is the john boat? Prices can be all over the place, but I'd say $650 is on the high side. $400 should buy you a pretty nice motor if you shop around... especially if you beat the spring rush. I doubt a 20hp will be in as high demand as engines in the 10hp range (so a larger discount may be in order)... the larger size/weight/hp makes them a little harder to move around and beyond capacity of typical 12' boats.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 6:24pm
Tim, what do you think the best prop selection for that type of HP and the factory hook on the John boat with Quinners ass sitting back by the tiller all tucked down for better aerodynamics?
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 6:28pm
Hey there I got one of them there 20 hp 70s Johnsons in the old outboard collection (don’t tell my father that’s what I call his basement) never ran it so I can’t comment directly on its ups and downs. If it runs good itll probably run good till it don’t, and that probably would be longer than you run good anyhow. For that money if should have been recently tuned, impellor changed, be pretty, etc. Basically a rock star. They are nice motors, but if you are going to do a lot of idling I would spend the money on a used 4 stroke. Make sure the tank is clean, free of rust, water and all sorts of whatnot.   Lower unit should not contain water, should contain fresh (although still quite foul smelling) lower unit lube.   Do you get to run it or dry inspection only?
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 6:33pm
Believe it's a sea horse model.
Seller claims it pushes his 14' Sylvan 28mph GPS, weight is 83lbs
Will be going on a 14' Alumicraft rated 15hp max
kytom2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kytom2 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 6:36pm
You will have more motor than boat. Had a 15 on an 16 ft boat, it pushed it along well!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 6:43pm
I think they were all Sea Horses. I don't know what a john boat is, but if it's a regular 14' aluminum, it'll be fine. I think the price is high, but if it's been gone through and runs well you probably won't find much as good that's any cheaper. I've got an '87 9.9 Johnson that's been trouble free since new. If it's been run regularly during its life is better than if it hasn't been run in years. In that case I'd be looking for the carb to be munged up.
I don't about where you are, but it's hard to find someone to work on that stuff around here. I believe I have a service manual that covers that motor if you ever need it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 7:32pm
I believe that speed... Ive got a 15hp on a small 12' rated for 10hp and it'll touch 26mph on the GPS. Im a firm believer in stepping moderately beyond a given hull's rated hp.
Zach, dont knock these little boats... you better believe Ive got mine tuned to run as fast as it can- jack plate and all!
Bruce, I believe a jon boat is the flat bottom, hard chine, flat front style boat... not a v-nose. They ride like crap but haul a$$.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 7:37pm
Then a 20 is way over powered. Our 14 Lund with 9.9 does about 25 and will pull a kid up on deep slalom. I used to trick ski behind it. Over powered little boats are a blast. I used to have a 12' StarCraft that was rated for 10 hp with an old 25 hp Johnson on it. It flew.
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 9:01pm
We never did before!
1987 Ski Nautique
john b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john b Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 10:36pm
Be sure to get a compression reading and that there is not more than 10lbs between cylinders. Check the gearcase to see if any lube has oozed from the seal area. It may need to be re-sealed if there is any leakage. Don't confuse the oil from the oil/fuel mixture to be gearcase leakage, examine it closely. Has it recently had an impeller? If not put in a new one before you run it. Check the condition of the rubber fuel lines and parts under the hood. Do they show any signs of cracking? Has the fuel pump been rebuilt within the past 10 years? The rubber diaphragms only last so long and ethanol can degrade them and older fuel lines a bit more rapidly. Cracks on the suction side of the pump can allow the introduction of air and give an inconsistent mixture. You don't want to run hard with a lean mixture. Check the throttle linkage for worn parts, if it has a lot of hours they can get sloppy and linkage parts can be expensive. Check the vertical pivot between the clamp and the engine (the one that makes it steer) pull on the gearcase while the engine is locked and see if there is any play. That is a problem that will seriously reduce the value of the engine.
I think the price is very fair if it is in good condition and passes all of these tests. Be careful, that is a lot of power for your jon boat.
Bet wishes..
1970 Mustang "Theseus' paradox"
If everyone else is doing it, you're too late!
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 10:43pm
Nice lookin' Johnrude there Quinner.
I've been on the search for the same or a merc.
The one thing that I would do is: pull the plugs and inspect the cylinders for scoring with a video inspection tool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2014 at 11:29am
Oh I knew you'd have an over powered turned up John boat haha. Our neighbor has one with a 15 Johnson. The motor lives in the shed. It gets out maybe once every 2-3 years. My brother will use it from time to time and it runs like a top.
We had a 77 Johnson 25 that my grandpa bought new. It was on his fishing boat and when he passed away I was born shortly there after so it was then stuck on a pontoon. Only thing we ever did to that engine was an ignition module and 2 fuel filters. I would own a Johnson 2 stroke over about anything else based on the experience we had with that and how well my brothers 84 70 horse runs. We owned the 25 up until about 2008ish. Sold it to a neighbor and she sold it in about 2012. Still ran like it was new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2014 at 11:53am
Zach you get them that "new" they are all good no matter the brand. Where you run into trouble is when you use them in salt or brackish water and neglect them. The castings are so thin now on smaller motors to keep the weight down they can corrode internally and not even know it by looking until it fails
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2014 at 12:31pm
Another plus for the older rigs vs newer used rigs Gary. The only thing I have done to my brothers engine is one of the plastic T fittings for the fuel lines between the carb broke. It was spraying into the air box and flooding the bottom carb/cylinder. Replaced the part and changed the plugs. Running like a top again.
My parents best friends have a 50 hp 2008 2 stroke Merc they leave at our place on a Toon. It never ran right. Took it to 3 different 2 stroke guys with the same results. I got mad and asked for Dave's permission to wrench. Popped the cover off and a few carb adjustments later it starts on the first key and idles all day long. I don't put any stock in most mechanics of any sort. Good thing most all of the guys here can do things like that or we would be paying people to mess our stuff up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2014 at 1:41pm
CQ,
I always got great help with my two stroke (75 HP Pontoon) from a web-site titled www.iboats.com. They have a forum section that is for Outboards. Then the Outboards are broken down my brand. Lots of experts concerning each brand that provide in-site and help. They keep me out of the shop for many many years.
Sorry to here that your Johnson has a tiny stroke.
