  New Posts New Posts RSS Feed - Tunable Rudder
Tunable Rudder
rockdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rockdog Quote  Post ReplyReply Direct Link To This Post Topic: Tunable Rudder
    Posted: February-21-2014 at 10:56am
Can I convert my non-tunable rudder in my 97SN to a tunable one? The trim tab is easily purchased, I just wonder whether anybody has cut the little section out of the rudder and fitted the tab? If so how did they do it? This would save buying a very expensive newer rudder.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2014 at 11:42am
You probably could if you have a buddy that has a machine shop. The cut towards the rear of the trim tab is rounded to cup the tab when it is tightened to hold it at said adjustment. You know you can tune the rudder without that right? What are you looking to accomplish? A fellow on the site is in need of an 11A rudder in Ireland. You could sell him yours and purchase a new tunable piece.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rockdog Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2014 at 7:36pm
No I didn't know my rudder could be tunable, how is this done?
Also I didn't realise the cut is rounded as you say, not sure whether that makes it more difficult to do or not, since I'm not sure what tooling is required to do the cut with.
I think selling to a different country would be cost prohibitive due to weight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2014 at 8:56pm
What's wrong with your rudder?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rockdog Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2014 at 9:16pm
Better to have tunable for running the course, my friend's 05SN has much better tracking, that's the reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2014 at 9:52pm
I always wondered how anyone skied a slalom course before that rudder with adjustable the plastic tab.
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2014 at 10:00pm
Don't mind Hollywood, he prefers a double dutch rudder, tunable is nice but once they are set it's no different then grinding yours a bit as/if necessary
Florida Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Florida Inboards Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2014 at 12:43am
tabbed rudders come up from time to on E-bay, I have one but am saving it for another project. keep in mind the early 11-A tabbed rudders are different then the 2002-current tabbed rudders. the newer rudders have a bigger surface area and are a bit longer overall.
Money Talks! BS Walks! and loose change rides the bus!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rockdog Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2014 at 1:55am
Thanks Jody, does it matter which one I use? I presume either would be OK?
Still unsure whether I can alter my existing one? Drop saw to cut the section out and grind the rounded part in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Florida Inboards Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2014 at 10:54am
A new model will work fine, however it imop is overkill on a older ski nautique. We went to that rudder because a one size fits most. the bigger direct drives needed something a little bigger then what we were installing in the SN so the rudder was enlarged and it did not impact the performance of the 196.
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2014 at 2:24pm
Belt sander or grinder to the right or left trailing edge of the rudder depending on which way you want it to pull. Doesn't take much grinding to make a big difference. Fwiw once I found a setting I liked I have not touched my tunable rudder so the quick-change functionality is kinda moot anyway.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2014 at 4:24pm
I agree. You don't need a fancy tuning tab to tune a rudder. It's been done as Joel stated since I'd say the 50's!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rockdog Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2014 at 10:19pm
Thanks for the tips everybody. Very helpful.
67nautique312 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67nautique312 Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2014 at 12:59pm
My promo is in dire need of this "Tuning"...especially after i put the 540 on it.....What are the details??? mine pulls to the left...grind on the left side?
1963 Classic (handed down to my daughter)
67 Riviera
68 barracuda
1971 Ski Nautique Promo
86 Silver Nautique
1995 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67nautique312 Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2014 at 1:40pm
After doing some research....looks like i need to grind on the right side to bring it back straight.
67 Riviera
68 barracuda
86 Silver Nautique
1995 Ski Nautique
