  New Posts New Posts RSS Feed - Auto Headlamp Brighten
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Topic: Auto Headlamp Brighten
    Posted: April-20-2014 at 1:28am
Well, Our old Subaru's headlamps were really cloudy and scratched up. I have been toying with the idea of using one of the headlamp restoration kits - but I thought it would be involved and with limited results.
The guy at our shop offered to do it for $50 ....(which is about 1/2 his shop rate).... so I figured he'd have one of his lackeys do it out back.
So, I figured if it was idiot-proof, I would give it a try......
I have liked Meguiar's stuff in the past, so I picked up this:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 1:31am
After masking the paint....this is what a headlamp looked like before ........
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 1:37am
Using the supplied sanding block, and P1000 followed by P3000 wet sandpaper...... We have this:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 1:39am
Using the supplied buffing pad and the plastic polish - the driver side looks like this:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 1:43am
So, this is the result after the buff and final protectant application...
Not bad for 30 minutes work (including the masking).
If you are hesitant - don't be! It was a huge difference, was easy and I have enough to do several vehicles.
davidg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidg Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 2:39am
Your headlights look like new. Nice job!
My son's '96 Mustang's headlights looked horrible after ~17 years of UV exposure. So, instead of the polishing kit, I ended up buying new headlights from Rockauto.com last year. Going from memory, I think the headlight assemblies were about $20-$25/each. Nice clear headlight lenses makes all the difference in the world on a car's appearance.
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 2:51am
For the really cheap crowd, if you have wet sanded you're boat then you already have the supplies to do this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 3:08am
Yeah Don, I figured it would get up my confidence for the gel wet sanding ahead! It sure did..............!
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 8:30am
Great job Steve. Looks new!
- waterdog -
78 Ski Tique
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 9:53am
Nice job Steve. I've used that kit before too with great results.
'92 Correctcraft Ski Nautique
ny_nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ny_nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 12:55pm
Steve you guys have some strange license plates in VA.
Nice job though!
- Jeff
1999 Ski Nautique
peter1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 2:36pm
Nice job though!
that plate should be reserved for a chevy
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2014 at 2:49pm
Looks good. I've been too afraid of some of those fancier kits. I've discovered Blue Magics headlamp polish. With minimal work, 5 minutes and just 2 rags I get equal before and after results. I sure do miss sealed beam headlights.
