  New Posts New Posts RSS Feed - 86 SN2001 drive shaft packing
LiquorBox View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LiquorBox Quote  Post ReplyReply Direct Link To This Post Topic: 86 SN2001 drive shaft packing
    Posted: April-25-2014 at 7:16pm
I have read two different forums regarding the drive shaft packing for a 1986 ski nautique 2001. Maybe someone here can help. Do I use 3/16 or 1/4 flax? I just put new 3/16 in but I am now second guessing it after reading a separate post today.
Thanks.
Treven
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2014 at 8:12pm
My 86 Silver Nautique took 3or4 circles of 3/16 teflon coated packing. The drive shaft is 1in. It depends on the packing nut. Make sure you remove ALL the old packing. Stand on your head and use a strong flash light to look into the nut.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2014 at 8:15pm
Treven,
All have excellent results with the Gortex GFO packing. I'm surprised you can even get the flax packing anymore since it's been outdated for probably 30 years. Maybe you are going to a marina or supply house who wants to dump the old junk on you!
Regarding the size, CC used both. You need to measure between the shaft and packing nut. Slipping a 3/16 or 1/4 drill bit in there works great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LiquorBox Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2014 at 8:27pm
I thought it was called flax lol. I bought the GFO packing, I will have to check the gap. The previous owner had 1/4 in there but it didn't come out so easy, kind if like it was forced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2014 at 8:43pm
+ 1 on the drill bit I forgot that trick Pete. The packing I bought is from a marine supply for commercial fishermen. It is difficult to remove the old packing. There is a cool tool that looks like a itty-bitty cork screw. I just dug it out with an o ring tool.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2014 at 9:52pm
Packing removal tool
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2014 at 9:55pm
Of course it doesn't come out easy. The purpose of the gland packing nut is to EXPAND the packing so it runs tight to the inside of the gland and shaft. That what keeps the water out!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote LiquorBox Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2014 at 1:33am
Glad I changed the 1/4 inch packing which the previous owner "crammed" into the packing nut! It was forced @8122pbrainard and that is what cause the leak. I replaced it with the 3/16 and everything worked great! Nothing better than 95 degree weather and no wind! Happy Friday.
boardersdad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boardersdad Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2014 at 5:32am
Welcome, Treven.
We bought our 1984 SN2001 last summer and my son and I have been doing all sorts of these maintenance jobs. I ordered both sizes of the packing--it's so cheap when compared to paying someone to do these things for you. I actually forget which size I ended up using, but I wrote good notes and keep them with the leftover packing (I bought plenty).
Something I'm glad we did--starting at the battery, we traced every circuit we could access (but not all of them up under the dash) and disassembled and cleaned every connection. It took my son and I under 2 hours, and it was worth every minute. He's been cleaning things up under the dash, as well.
Another job I thought was worth doing was lapping the prop to the shaft. And I bought a used prop puller, and now I have two (TWO!) spare SN2001 props that I have along (on one of the two boats)--I've learned to be prepared so a vacation doesn't get ruined, if at all possible.
Lots of other good things discussed here at CCF. Labors of love.
Steve
dustyb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustyb Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2014 at 2:16pm
where are you guys getting the packing from? im having a hard time finding it for some reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LiquorBox Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2014 at 2:50pm
I bought mine from nautiqueparts.com
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2014 at 3:16pm
Ski Dim sells it too.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2014 at 3:48pm
I got it, You can find it at like 1000 different places online sometimes not even marine specific stores. I haven't found a good source for Gore-Tex yet that I can supply at a sellable price but I love the product.
