It will never be a BFN, but... |
Author | ||||
IAughtNaut
Grand Poobah Joined: August-22-2010 Location: TN Status: Offline Points: 2568 |
Posted: June-12-2014 at 3:41pm |
I wonder if I can improve the shape of the wake behind my boat at barefoot speed?
Anyone ever play around with weighing down a Sport or Air for anything other than wakeboarding or surfing? I know its not the same hull, but there are so few Pro Airs out there I feel like I better widen my question. Before anyone asks, I'm not trying to put 4000# and do 40 (partly because I don't think the boat will do it), but if I throw a couple hundred in the nose will it knock the rooster tail down or flatten out the wash in the middle? Is this just a terrible idea? Here's a shot of the wake at 39, probably 6-7 people on board. |
NCH20SKIER
Grand Poobah Joined: December-16-2004 Location: United States Status: Offline Points: 2207 |
Just go ahead and pick up a second boat - everyone should have at least 2
'88 BFN |
NCH20SKIER
Just go ahead and purchase a second boat - everyone should have at least 2. Besides it is much easier to justify when you are single without kids
'88 BFN |
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3357 |
think i may be best to have only two in the boat..
but I concur, formula for number of boats one should have is N + 1, where N is the number of boats one curently has. If you like to foot 7 at a time, consider a sanger outboard. |
River Rat to Mole |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21168 |
Meh, if you want to foot 7 at once, you better get something that can pull better than a single OB... think big block! N+1 Tom, that's perfect.
Adam, I think this is going to be a losing battle. Keeping the boat light may help a little, but really there are only 2 things that are going to be of significant improvement. 1)Use a long rope... yours looks way short. Im talking full length- all 100' of a BI rope *might* get you far enough back to survive that table. But really, the thing that will help you most is 2)stay the heck outside the wake. No better spot to be than the curl. Honestly, most CC's other than the BFN (or other similar v-hulls) throw pretty crappy barefoot wakes. This includes every Ski Nautique ever made. They are marginally survivable if you have a long enough rope, but you still dont want to spend any amount of time there. Your hull, with its inverted strakes is trying to suck the hull deeper in the water, making the rooster tail and prop wash even more formidable. I dont think that there is a simple solution that is going to overcome that. |
IAughtNaut
But just because I'm not a father doesn't mean I don't have kids to take care of, this week alone I was "babysitting" a 22, 24, and a 25 year old.
**note, absolutely no engineering knowledge/experience went into this theory. |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5778 |
Only one way to find out is try it Adam, I try to accomplish the same thing with the 200 Sport and when I run slalom I load the nose with all extra weight, it makes a difference. Granted I have extra help with the gate down than you do but the weight up front still is noticeable. I found this out when I skied with 5 people in the boat, 2 went up front to clear the rope and I was like oooh I like that, of course the driver hates it. I've even considered adding some water to our nose bag but I haven't tried it yet. |
IAughtNaut
That's encouraging Alan, makes me think I got a shot. I'm definitely gonna give it a try, just wanted to see what some of the brain trust thought...or if anyone was like, terrible idea, you're gonna sink the boat, or that will be too much pressure on the shaft at that speed...probably unlikely, but I'm an idiot so I have no idea.
Adding weight up front is definitely going to plant the nose and make the wake smaller, as Alan said. I doubt it will have as significant of an effect on the table and turbulence, but it wont hurt to try. 400-500 lbs up front is probably a bit much though- maybe try 100-200 first and make sure the boat still drives ok?
IAughtNaut
I'll probably play around with a fat sack instead of people, just because its easier for the driver to see when there's not anybody in front of them. I feel like this is going to be a real moving target depending on who's on the boat.
IAughtNaut
And another thing...wake size and shape gets discussed ad nausea, nobody ever mentions the rooster tail. That I think is going to be my hurdle, cause I know that thing smacks me in the knees when I slalom, I feel like trying to foot through that is a recipe for a faceplant. What contributes to size, shape, and far-backness of the rooster tail? Obviously I'm not changing the shape of the hull, but something in my control has to impact that.
81nautique
And when you sink the nose the fat sacks don't give you dirty looks. . Your boat will handle the weight better than mine but nose weight on the 200 is a job for the driver. |
Adam, a 100' line will have you behind the rooster tail by a good margin... probably 30-40'. You should be behind it even with a 70' line, which is probably what HW is using in that picture. The size and intensity of the rooster directly contributes to the turbulence and the "wake within a wake" features directly behind it, which are very difficult to foot through by themselves... no way are you going to survive footing in the rooster tail if your rope is that short, no matter what kind of weight youre running in the boat.
You are unlikely to be able to make any measurable change to where that rooster tail occurs (distance from the boat). That is a function of hull shape and boat speed. You might be able to tame the intensity by lightening the boat as much as possible and moving as much weight forward in the boat as you can (as discussed). |
IAughtNaut
sounds simple enough, only skinny girls on the boat and everybody moves to the front when uncle deeno's doing work. got it.
Air206
Hydrogate?
..... I personally like the whole "trim tab" concept on the Excels..... but that's a different kettle o' worms! Zach - what would say about a hydrogate retro-fit, like on Mark's BFN? |
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13513 |
With people you can at least shift the weight back immediately after a run, even for the turnaround.
Running light includes low(er) on fuel. Definitely 100' of rope, crossings will be rough. You might be able to find a little flat spot on the side of the table to ride out a rough patch of water else "do work" in the curl. Props to you for going longline and not dangling on the boom. |
Hollywood
And that picture is about as rough as it is going to get. Fully loaded with people, gear and fuel. I don't remember the line length but I know it was a wakeboard rope. I doubt it was 80, more like 60. I had no intention of crossing that rooster.
IAughtNaut
I also want to learn some wake crossings, I'm just wondering how bad its gonna be with my wake. Guess its gonna be a good ole grip it and rip it. |
Hollywood
That's really the best way to do it behind any boat. Don't think about it. Don't look at it. Don't even think about looking at it. |
kapla
Wake crossing in a nautique= mission impossible!
<a href="">1992 ski nautique
IAughtNaut
AAM196
Gold Member Joined: October-23-2012 Location: Pittsburgh, PA Status: Offline Points: 846 |
I remember Scarpa's bu had a trim plate on the transom.. the table on it was almost as good as a mid 80's BFN. I don't know if the "scarpa plate" had any effect on the rooster tail or just shaped the wake a bit and got it on plane faster. Either way I just deal with my SN wake and let out the line.
Good for you kickin the boom habbit! My advise is leave the ski in the boat and forget about kickin a ski off. I actually think it is easier to deep water behind a boat with a novice driver than worry about a new driver driving with a boom. Just make sure you pick a driver with good eyes so you don't get pulled over debris! Just be smooth working on the three point and have good posture... keep your knees 90degrees... Good luck! |
IAughtNaut
That's interesting Andrew...I mean, your preference for long line to boom with an novice driver. I just find that boom makes up for a lot...both skier and driver.
Here's the way I think about it, regardless of if HW says I shouldn't be thinking- I can get up on a slalom with anyone driving I can barefoot once I'm on my feet at speed I am more confident in my ability to get a rookie driver to speed if I'm on a ski and I know they can't hurt me. At this point I have exactly two successful long line deep starts under my belt, with an excellent driver...so I am by no means a pro. When I get down south next week with my dad I'll leave the ski on the beach and let him pull me all day, but its 2:00 on a Friday and I don't even know who's going out with me tomorrow yet, haha |
AAM196
Adam,
Too Bad you are from Cleveland... (for multiple reasons, lol) but we both have the same problem! The truth is, I rarely barefoot or ski without a competent driver at hand. I guess what I am saying is it seems when I am on a boom I am more likely to need multiple speeds etc plus beginner drivers aren't used to the way the boat pulls dragging skier on boom and even bury the boom turning sharp the wrong way etc. I even watched a driver smack someone in the head with the boom... just needed to tell the skier hold on... wave coming... but failed to open his mouth. I guess I hate boating in general with non-boaters... nothing worse than sitting at a dock with 4 grown adults in boat when a wake comes and no one even thinks to hold the boat off the dock. |
IAughtNaut
I try to make it easy, only turn the boat at idle, I make sure to tell them its going to pull left with me on the boom, and some times I'll even pull the boat around from the water so its pointing the right way, haha
gun-driver
Go ahead and get a BFN Adam I have room to store it for you, heck I'll even take it out and exercise once in awhile for ya |
IAughtNaut
its that kind of selflessness that makes this site great...actually, I did just see a big block bfn on ebay yesterday for $2500, I was tempted, but then remembered everything else that I need to pay off before buying a boat I don't need...I put it on the craigslist thread if you want a 3rd boat. I'll even bring you your oil pan and teach you to drive it!
