Need Help Pulling the Motor:( |
95montana
Newbie Joined: July-01-2014 Location: United States Status: Offline Points: 2 |
Posted: July-01-2014 at 1:30am |
I have a 1986 model 2001 that I spent 100 hours redoing the stringers and rebuilding the entire interior a couple years ago. I have a low end knock at WOT and loose oil pressure. My engine guy says main bearing or rod and motor needs to come out. Any tricks or things I should look out for? Looks very straight forward to me and want to get back on the lake...
Thank You in Advance for the help. |
1986 model 2001 gutted to hull and completely rebuilt from inside out.
Smithfamily
Platinum Member Joined: December-26-2007 Location: Orlando, Fl Status: Offline Points: 1602 |
1992 SN, I pulled the motor for a rebuild. Covered the interior in plastic, pulled motor with transmission attached. Taking my time and being cautious, I think it took 3-4 hours. It was not a big deal. Rebuild cost $1800.00 from a professional shop. (4 years ago)
Js
mamigacz
Groupie Joined: June-08-2014 Location: Wisconsin Status: Offline Points: 96 |
My cherry picker would not raise high enough to get the engine over the side of the boat. I ended up using a chain hoist. See below:
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3359 |
Consider removing a trailer wheel to get the boat lower before you begin.
Install a fresh trans dampner on the flywheel upon reassembly. |
River Rat to Mole |
