Airguide Speedo Question |
Big Jim Slade
Groupie Joined: July-12-2004 Location: United States Status: Offline Points: 67 |
Posted: July-21-2014 at 12:40pm |
Does air or water move the speedo? With the name Airguide I certainly have an idea.
Morfoot
Combination of both Jim..... Air in the line is forced into the gage moving the needle under the pressure applied to it from water being forced into the pitot (pickup).
Airguide made a variety of Nautical items. Compasses, barometers, hygrometers etc. The first Airguide I ever remember was the compass in my dads old 71 PU attached to the windshield. |
AAM196
Gold Member Joined: October-23-2012 Location: Pittsburgh, PA Status: Offline Points: 846 |
Not to thread jack, but I remember we were on the cusp of having a GPS module for our airguides.. was this ever brought to market?
Yes I think it's classic boat works but not sure
Morfoot
Big Jim Slade
So my original message was a bit longer and more detailed and when I tried to post it, the forum decided to crap out and erase it. Since I'm still not completely clear on the issue I'll include a few more details.
When I first launched the boat this year I had one dead speedo and soon discovered (another) water leak. When I finally started digging into it I turned out to be the easiest thing I’ve ever fixed on Big Jim. Once I pulled the rear floor up I discovered my wonderful repair shop forgot to reconnect the speedo line, which for some unknown reason isn’t one hose (from Pitot to speedo) and instead is two, connected together with a little nipple connector. This was apart and leaking a steady stream of water into the boat. Now that this is reconnected the line is full of water and in the interest of protecting my speedo, I disconnected it from the speedo end thinking I didn’t want it to fill with water. From what I’m reading it appears as if I need to pull the boat from the water, drain the water from the speedo hose, reconnect it and then relaunch the boat. Sounds right? Anybody have a reasonably priced boat lift for a 16' CC available |
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3749 |
You can remove the hose from the speedometer and blow air back down and out the back without pulling the boat from the water. You just don't want bubbles in the line. Blowing air down will clear the line and you are good to re connect at the speedo.
AAM196
water in the line isn't a problem. You can blow the line clear as described bellow. Also, carry a tiny drill bit to clear out the little pin hole in pick up. And enjoy your airguides and the daily issues with them.
There is always the GPS conversion unless you boat on rivers. |
Big Jim Slade
I ran it yesterday with the line disconnected from the speedo and it pushed all sorts of nasty *************** out of the hose. I'm guessing the drill bit/clean the pickup pitot has already been resolved as I have lots of nice clear lake water now pouring onto my feet when moving at a decent clip.
Big Jim Slade
When I blow air back out of the line do I need to cap it with my finger quick or connect it back up to the speedo super fast before water starts entering the line again?
AAM196
I don't think it really matters.. sounds like your all set. Keep the drill bit in your boat... you'll need it at some point
MrMcD
Once you blow the air down you are done. No need to cap it or rush.
Hook it back up when you have time. I have always believed you wanted the water pushing on air in the line with no water in the line except for the water pushing into the tube at the back of the boat. Maybe that is not the case. |
Big Jim Slade
I just wanted to be sure I wasn't going to fill my speedo with water as it took me a long time to find one that was a match to the single my boat came with.
AAM196
after you blow the line clear hook it back up. If you drive boat again before you hook it up, then yes water will flow thru tube, if you don't move there will not be any pressure in line and you can hook up without worry of water spraying out.
If you hook perfect pas up and remove a speedo... plug your extra tube or you will get wet toes... lol |
Morfoot
Drill bit works well but trying to hand drill out an obstruction in your pitot can be quite challenging. I keep this with me in the pouch by my right knee.
As you can see its nothing but a syringe with plastic tubing on the end. Disconnect the Speedo tube at the pitot,draw water in the syringe and connect its' tube end to your pitot, then back pressure the obstruction out with water. It's worked for me 99% of the time w/o fail. The other 1% usually takes a fish hook or drill bit to remove the wood that was driven in with a sledge hammer. |
baitkiller
Is that your catheter?
I get sand in them all the time. I just have a larger size paper clip I use to poke them out. Working so far and i get scared of pulling off the hose because the little barb ends break pretty easy, i have one ghetto rigged back together already. Im actually saving my milk money for a set of Gaffrig stainless Pitots but they get pretty spendy. |
