  New Posts New Posts RSS Feed - Exhaust Manifold Crud
MI-nick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Topic: Exhaust Manifold Crud
    Posted: October-31-2014 at 2:54pm
This is what came out of the manifolds when I drained this year...actually this is what I usually get. '99 SAN with GT-40 ~900hrs...~100hrs this summer. normal?? concern?? It looks like rust flakes...but not quite...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 3:10pm
You will get rust when draining a cast iron manifold. Do you get this much crud on an annual basis? The first time I drained there was a lot, but not as much year after year now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 4:04pm
that seems to be pretty much "normal" for this boat...my '88 has some too...but maybe ~1/8 the amount...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 11:04pm
More than I ever get out of PCM ones,the aluminium HM's get nothing out. Maybe your water is on the acidic side?
malibud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote malibud Quote  Post ReplyReply Direct Link To This Post Posted: November-07-2014 at 10:01am
I think that is normal. wow and a hundred hours in one season up there. I am lucky to see 40 in NC
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: November-07-2014 at 10:46am
I do between 70-110 hours a season and never get anything out of my PCM manifolds. They are stored dry every winter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-07-2014 at 2:33pm
I guess there's a chance you sucked up some muck/crud at one time that settled in the manifolds.
Do you drain them every year?
