oil cap gasket? |
dfaust
Newbie Joined: February-05-2015 Location: Rochester ny Status: Offline Points: 17 |
Posted: February-08-2015 at 10:07pm |
Hello, I have a 1981 PCM 351W that has a worn out gasket between the oil fill cap and the valve cover. I have not been able to identify a source for this gasket nor have I been able to find a part number. Is this gasket intended to be there? I suppose I could make one, I was just hoping to find one already made up.
Thanks |
Doug Faust
Gasket cutter:
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4234 |
They don't tend to seal all that well anyway, but if it's gone you can cut a new one to fit. Nothing much should come out of it, are you seeing much of anything blowing out of the fill pipe?
dfaust
Thanks for the responses. I recently had the valve covers off for cleaning/painting and new gaskets. I did not specifically notice any evidence of oil leaking around the filler cap, however the gasket was still mostly complete. I'll just make a new one.
Thanks |
Doug Faust
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6148 |
Also, you can bend the spring material back up a little bit to make the cap have a tighter clamp to the valve cover when it's tight.
