1965 Nautique Update |
Post Reply | Page 123 4> |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4239 |
Posted: September-13-2023 at 10:59am |
Nice to have a spare on hand to swap in there, and even nicer that it ended up working. Great to see that boat getting used in 2023, 57 years old if I did the math correctly.
70CC
Senior Member Joined: June-12-2006 Location: United States Status: Offline Points: 338 |
It's been awhile since I've posted. Here's an update on the '65 Nautique:
Last summer the rebuilt 71C transmission with maybe 10 hours of use failed. I was pulling into the boat lift, went into reverse to slow down, and the boat stalled. Went to neutral, started the boat, and it lurched forward, almost going through the lift - that would have been bad! Shifting into reverse stalled the boat again. After getting the boat safely on the lift I determined the transmission was stuck in forward. Could have been so much worse as I think of the times where I have pulled up to a dock, counting on reverse to slow me down. Well that was it for summer of 2022. Fortunately, I had a spare 71C from one of the marine engines that I bought for parts. It was an early unit mated to an early FE in unknown condition. At least the fluid looked OK and so I thought it was worth giving a try. At a minimum it would be a place-holder to attach the motor mounts to and hold up the rear of the motor while working on the failed transmission. Degreased, and with a quick shot of paint to match the motor, it was ready to install. The swap went well. I used some lifting ears that came with one of the engines to suspend the rear of the motor. Glad I installed studs in place of the lowest two bolts when the first transmission was installed to help guide the transmission into place. After getting things bolted up, I went to the boat ramp. Boat started, no leaks, so far so good. Let it warm up, then checked forward and reverse. Still no leaks and seemed to be going into gear properly. Checked and added some fluid and took a cruise, everything worked fine. I now have a couple of hours of cruising and all seems to be ok. One of my winter projects will be tearing into the transmission that I pulled out to find out what happened and hopefully can fix it.
davidg
Sweet boat! Very nice work. I bet that 390 sounds sweet! Love them FE motors.
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Offline Points: 947 |
Awesome to see it back pulling skiers. A job well done.
63 Skier
Boat looks amazing, and love the picture with the skier! If it's possible for a boat to be smiling, that one is.
67 ski nat
Platinum Member Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1184 |
Next years calender entry winner
67 ski nat
Very nice 65, well done sir
Phil,
Thanks for all your efforts into a fantastic restoration.
Beautiful Phil
70CC
Pulling its first skier in about 30 years...
70CC
Velvet drive updated with neutral safety switch - thanks again to Ken. Motor box and rear hatch cover added.
Grand Poobah Joined: June-06-2004 Location: United States Status: Online Points: 10717 |
The USPS has the package now, says it'll be there on Wednesday.
I'll send a tracking number in a PM later today
70CC
Fantastic! PM sent. Thanks!
Phil
I dug through my "pile of parts that might come in handy for somebody one day" and came up with what's in the picture. It's the cam and the plate you need. I found a dead switch, but that won't do you any good. This plate takes the newer NSS that has a 7/8 hex head. The PCM part number is R153011 for the switch. The part number listed and linked earlier will fit. There's a wide variety of prices when you get looking. It's cheaper than the old bigger switch too Send me a PM with your address and they'll be on the way to Iowa for a worthy boat. We'll call it a donation to your project
Like he mentioned he needs the cover/mounting plate and the cam too, not just a switch
67 ski nat
Try. 1000-640-004. Velvet neutral switch
67 ski nat
I believe the neutral switch is still available new. I found one on eBay, bought one as a spare
70CC
I'm looking for a few items to finish off this project:
The Ski Nautique script that goes on dash is broken in two pieces. I believe its the same emblem used on the Gen 2 boats, and maybe even the 2001's? My 71C does not have a neutral safety switch. If anyone has a junk Velvet Drive laying around, I'm interested in the switch, the mounting plate, and the cam that actuates the switch (like the one shown here). Send me pm if you have either of these. Thanks! |
wayoutthere
That is a beautiful boat, you guys that do the period correct/showroom restorations have skill and patience on a whole nother level.
Mojo
05' SV211 TE
70CC
I've been taking it easy breaking in the motor, but so far I'm pretty happy with the way the 390 is running.
The distributor is a Mallory marine unit with points. I'm running a Carter 4 BBL (I believe this to be the original carb) converted to electric choke. Idle is smooth, throttle response is nice and snappy with no bog. I have to give a shout out to Gary Myers from Motorheads Mfg in Ely for doing the machine work and assembly, working with parts from multiple motors. |
Way to go Phil! long journey but worth it
skutsch
Phil - That is so AWESOME. Can't wait to hear how she continues to run. GREAT WORK!!!
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3889 |
WOW nice work and thanks for sharing this.
67 ski nat
Bad ass. Very happy for you. Beauty
Thanks for action pictures -brother from a different mother- |
Phil,
Keep us informed on how that FE runs.
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1736 |
Beautiful Boat! Very nice work.
Phil,
Fantastic to say the very least. I knew you'd get it in the water one of these days. Looks great.
70CC
At long last... the '65 is in the water and running again! (after at least 30 years, 11 of those in my possession)
Initial start on a garden hose went well until it started to rain, Next I dipped the boat in the Cedar River on the trailer to finish breaking in the cam, test the complete raw water system and transmission shifting. Found my thermostat housing was leaking, fixed that, then trailered to Lake Delhi for the shake down cruise.
Docked next to the 97: Running down river about 25 MPH Thanks to Keith and everyone on CCFan that has helped with this project and provided moral support along the way, especially Art who found the original bill of sale and helped with the missing puzzle pieces. |
