water leaking form my motor |
LeftFieldEngineering
Senior Member Joined: December-20-2010 Location: Monson, MA Status: Offline Points: 384 |
Posted: April-24-2015 at 9:14am |
My '79 Tique was leaking from the bellhousing. The 302 block was cracked on both sides, the left being worse, one poke with a screwdriver and the piece fell right out. I hope it turns out better then mine.
JDD33
Senior Member Joined: October-20-2012 Location: Natick, MA Status: Online Points: 499 |
I just went out and looked at the 351W I have on the engine stand and it's the same as the first pic. That's a lot of water..... Need to pull the trans. |
Old school goin back to school!
Are you sure? There are freeze plugs back there on a 302.
mamigacz
Groupie Joined: June-08-2014 Location: Wisconsin Status: Offline Points: 96 |
your engine is a 351W, right?
If so, there are no water freeze plugs in the back of the engine If its a chevy, there are two. |
That's a pretty decent leak. I agree that you need to find out what's causing it before using the boat. Here's a direct link.
iliaskass
Newbie Joined: April-04-2015 Location: phoenix Status: Offline Points: 5 |
i hear that brother!! What would cause a crack in the that part?? motor mounts??
DrCC
Large round part = bellhousing
Personally I would not use the boat till you find where the water is coming from. (saw the vid) If you starve the exhaust hose from water you will then burn a hole, then sink to the bottom. Not boating is never fun, but it's a whole lot better than sinking. |
iliaskass
im not sure large round part that is between the motor and trans. i have no idea what purpose that part has. did you look at the video? its on my sec post
CrazyCanuck
Senior Member Joined: July-21-2013 Location: Vancouver B.C. Status: Offline Points: 254 |
Could a frost plug have popped out part way?
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
iliaskass
https://www.youtube.com/watch?v=6h5WJX0nLgE
So here is a link with a video i tool today. Let me know what you think. Also is it safe to take out like this. No water in the oil or trans fluid. Thanks so very much ilias |
Could be pretty bad - cracked block from freeze damage. I would pop the transmission off and have a look. If there is no water in the oil and the engine is otherwise good then perhaps drain the engine and apply some job weld.
iliaskass
water leaking between my tranny and motor plz help
