Rub Rail Attachment on 85 |
chuckactor
Senior Member Joined: August-20-2013 Location: Ft Collins CO Status: Offline Points: 102 |
Posted: April-29-2015 at 1:09pm |
I have my '85 2001 stripped down and being sanded and buffed out. I went ahead and removed the rub rail and purchased a new one. The original was held on by a ton of what looks like 1" #8 flat head screws. Should I use the same type of screws to install the new one? Would it be better to use a pan head type screw to avoid ripples in the rub-rail during install?
Also, I assume I need to pilot drill each hole. Should I leave the hole in the rub rail slightly bigger than the screw? Thanks! Chuck |
gun-driver
Should I use the same type of screws to install the new one? Yes
Would it be better to use a pan head type screw No I assume I need to pilot drill each hole Yes to avoid ripples in the rub-rail during install... Do it in the sun on a hot day then give it a (TINY) bit of strech. The trick is to not over tighten the screw which buldges the rubber. I filled all the old holes with thickened epoxy before installing the new one. |
chuckactor
Wow! I hope mine ends up half as nice. Mine is grey hull with Burgundy stripes. Mine was so faded I couldn't even tell the shadow on the letters was red originally. Do you think it would be OK caulking the old holes... As you know, there are a ton of them.
Chuck |
Chuck,
The danger of caulking is running into a old hole with the new install. Fill then as recommended with thickened epoxy. If you like the idea of a caulking gun, they do have empties. Fill one up with the epoxy mix and go for it! |
gun-driver
Paul,
I too use syringes. Good old McMaster has them in a variety of sizes. Cheap and I think they comes in bags of 20. Let the epoxy cure and you can pull the left over slug out and use it again/ |
captbob626
Senior Member Joined: September-12-2013 Location: Cape MAy,NJ Status: Offline Points: 203 |
I bought # 8 1 1/4" truss head scores from Jamestown dist. Work well without spreading rub rail.
Bob Meimbresse
