  New Posts New Posts RSS Feed - Oil change on 1997 Ski Natique
Cherrier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cherrier Quote  Post ReplyReply Direct Link To This Post Topic: Oil change on 1997 Ski Natique
    Posted: May-31-2015 at 4:55pm
How do you remove the old oil from the engine? Techniques?
jhersey29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2015 at 5:06pm
Should have drain tube on the oil pan that you put through the water drain plug. Find the tube, warm it up with a lake or water supply, put the tube through the hull drain into a container. 5 quarts or several cleaned and dry orange juice containers, take the containers to oil change place for recycling. Swap filter after drained. It will have oil in it so clean up the dripage and replace filter. Put oil in the filter before reinstalling to minimize the lack of oil to the motor on first start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2015 at 5:10pm
Ann,
What year boat do you have? Since the mid 70's, CC's have been equipping engines with drain hoses that you put through the garboard drain close to the keel. This of course must be done with the boat out of the water. If you don't have the hose or it's not out of the water, a vacuum pump device is used to suck it out via the dip stick hole. There are plenty out there. Google "oil vacuum extractor".
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2015 at 5:11pm
Only later engines! My 77 has one but even hanging in the boat house, I find it more convenient to suck it out. I tried getting the drain pan on planks under the boat in the wet slip and I ended up getting wet myself!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cherrier Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2015 at 5:23pm
Thanks, guys! Thought oil had to be sucked out as only option, didn't know about drain tube. Boat is out of water at the moment due to steering cable replacement. It's 70 degrees in Alaska and we can't go skiing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2015 at 10:52pm
Ann,
Did you take it to the idiots who told you the floor needs to come out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cherrier Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2015 at 2:38am
No!!! My husband and I brought the boat home from the lake and are going to tackle the job this week. This forum has been the absolute best. Thank you to everyone who offered their advice and expertise. Ann
john_33612 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john_33612 Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2015 at 3:09pm
I stick the drain hose in a milk jug and put air pressure in the PVC hole , cap breather hole with other hand , not to much or may blow a seal , oil being hot helps , boat on lift so I can't put hose in the drain hole
