  New Posts New Posts RSS Feed - Will not Idle
Will not Idle
seen-nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote seen-nc Quote  Post ReplyReply Direct Link To This Post Topic: Will not Idle
    Posted: May-22-2006 at 12:46pm
1990-sn 351 carb.
Had the boat 6 seasons now, always garage keep...
Always stored for winter with stay built and carb fog…
This season, we started leaving the boat in the water...
Changes the plugs, rotor cap and button,
Carb. Cleaner in tank, carb.
Cleaner in carb while running...
Changed water fuel filter...
Still will not idle.. can run all rpms after 900
Anything below 900rpm will stall out…
Fresh water lake…
What is left before rebuilding the carb??????
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2006 at 2:05pm
maybe checking the timing, adjusting the carb, checking the choke stat. Sounds like the rest of the tune up needs finished.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2006 at 2:07pm
Check for vacuum leak.
Tim D
Nautique2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautique2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2006 at 3:23pm
Choke sticking?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautique2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2006 at 3:24pm
Air vent to gas tank clogged up?
stang72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2006 at 11:02pm
Agree with Tim...check for vac. leaks.
stang
The Super Air
77stang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77stang Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 12:35am
i had this exact problem the first two years i owned the boat. would drive me crazy in no wake zones near docks and so forth. i had a vac leak in the carb gasket. i puchased the standard holly gasket from a local auto store and it still leaked. ended up getting one from whitelake that was thicker. solved the problem immediatly and ive had a 500rpm idle ever since.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 12:50am
77stang is right...auto parts store will most likely get it wrong! Thanks to J_I_H ...thanks JIM...I now use a felpro gasket on the carb that fits right!Drove me nuts trying to get a good idle!
If you want the gasket number, let me know...I will head to the garage and check the # on the spare I have.
stang
The Super Air
