Friday Folly ~~~~ |
iplan
Senior Member Joined: April-19-2010 Location: Lake Murry SC Status: Offline Points: 201 |
Posted: June-19-2015 at 4:59pm |
So ~~~~ finally finished the outside painting and got my new decals on yesterday, and we were (emphasis on "were') headed out to the lake this afternoon.
As I was looking at the drain plug holes ~ I noticed that the hole on the port side of the engine block didn't seem to have any visible threads for the nut to lock down onto..... Sure enough ~ when I attempted to put the nut on, it would not lock down. Is there a quick way re-thread this hole myself? My weekend is counting on it! |
85 Ski Nautique 2001.
Stringer replacement job completed July 3 2014. Exterior painted June 2015. The Trailer is next. |
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13513 |
Sure you're looking at the right hole?
phatsat67
That's what she said.
iplan
This is the port side drain hole plug.....[hopefully not upside down this time]
iplan
Hollywood
seems like there's plenty of meat there to upsize the tap
Air206
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3359 |
Since NPT is tapered. I think just run the same 1/4" NPT tap a little deeper and you can get a new pipe plug to bite.
River Rat to Mole |
DrCC
I gotta agree with Gotta. Run a 1/4" pipe tap, then install your plug with 2 or 3 wraps of teflon tape.
SNobsessed
Brass plug is best too, won't rust to the block threads like old one apparently did.
iplan
Went to NAPA, and they said exactly the same thing you guys suggested about cleaning out the existing tap ~ without making it bigger. Bought the pipe tap for the same sized hole.... and new plugs. Put the tap in the holes, applied the Teflon tape, and no leaking ~ so I took it out. After a long warm up, I ran it for about 20 minutes at 2000 rpm, and drove to a little cove to watch the sun set.. All gauges ran normal. On the way home, I opened it up ~ to 34mph ~ for a couple of minutes. A few minutes later, when I was docking, the TEMP light came on. ;( 2 steps forward ~ 1 back..... but man, what a great sunset. So I guess, I'll follow the usual steps to troubleshoot the overheating.... Impeller, etc.? |
GottaSki
Mine gets a new one every year so I don't have to mess with it when the lake is glass and the lake lice are waking up.
River Rat to Mole |
iplan
Well ~ think I found the problem. and Question is, "do I need to do some "xplor'in" to clear any blockages?" I gave a half hearted attempt at checking the t-stat, but the hoses would not budge after the tension on the hose fasteners/ clamps were released , so rather than risk tearing up existing hose, I figured I'd ask for opinions first. Keep in mind, the boat ran fine all evening, and the Temp light came on at idle at the end.....(after the initial warm-up) did not idle much after that until coming back to the dock.. |
