  New Posts New Posts RSS Feed - GT-40 Temp Guage
GT-40 Temp Guage
2000CanadaNautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2000CanadaNautique Quote  Post ReplyReply Direct Link To This Post Topic: GT-40 Temp Guage
    Posted: August-04-2015 at 6:01pm
My temp guage stopped working on my 2000 Air Nautique GT-40. Do I need to special order a guage?
a0128 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote a0128 Quote  Post ReplyReply Direct Link To This Post Posted: August-04-2015 at 7:40pm
No special order. Teleflex still makes a replacement. You should be able to order from Zach at N3 Boatworks. 317-845-9253.
I assumed you got a VOM and checked the gauge out to eliminate other possibilities (i.e. sending unit)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2000CanadaNautique Quote  Post ReplyReply Direct Link To This Post Posted: August-04-2015 at 9:11pm
I will check the sending unit also. Will it be ordered in or will a regular auto store have it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote a0128 Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2015 at 1:59pm
Originally posted by 2000CanadaNautique 2000CanadaNautique wrote:
. . . will a regular auto store have it.
I believe the sending unit is specific to the PCM marinization as it has to interface with the engine's ECM.
Specific part number for the sender is R020024. Zack @ N3 will either have it in stock or can order it.
JayG80 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayG80 Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2015 at 10:15am
GT 40 Temp sender testing
The sender for the gauge has one tan wire that goes to gauge.   The gauge sender is on the front of the engine and located near the recirculating water pump. Within my post above is a link on troubleshooting the sensor with ohm meter.
A bit of sand paper on the ring terminal wire connector and tightening the nut on top of the sender cured my gauge issue.
I think there is a separate 2 wire temperature sending unit for the ECM.
2007 Ski
2002 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayG80 Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2015 at 10:23am
GT 40 Temp Gauge Sender
Above link to R020002 is the temperature sender for the gauge - not the temperature sender for the ECM. This $16, one wire sender is the one I reference in my post above.
2007 Ski
2002 Ski
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2015 at 12:58pm
Isn't there two temp sensors? One for the ECM and the other for the dash. I think the one on the circ pump is the dash and the one on the intake is the ECM.
Tim D
jhersey29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2015 at 12:27am
2 temp sensors and 1 temp switch. 1 temp for gauge, 1 for the ECM and 1 switch for limp mode to ECM,
