  New Posts New Posts RSS Feed - SNOB Bow questions
SNOB Bow questions
94Naut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 94Naut Quote  Post ReplyReply Direct Link To This Post Topic: SNOB Bow questions
    Posted: September-21-2015 at 1:26am
The bow handrails on my 1994 SNOB are slightly loose. Can anyone tell me how I can tighten them? I have crawled underneath as far as I can and can not even come close to reaching the nut on the underside of the rails to tighten.
I am sorry if this has been asked and answered. If so can you steer me in the right direction? Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2015 at 10:46am
Well, that's where the nuts are. You have to get to them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2015 at 11:43am
Aren't there access holes under the side upholstered cushions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 94Naut Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2015 at 11:51am
I was hoping that was the case. What is the process for removing the upholstered side Panals in the bow? The only screws I see are under the Velcro flap at the front, is that it? Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2015 at 12:05pm
For hard-to-reach places, I use a ratchet/socket combo with several extensions + universal joint(s) for the bends.
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2015 at 12:23pm
The process involves a highly trained lemur. Very highly trained.
Just kidding, this link might help you a little bit:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=23824&title=93-sport-coaming-pads
Although, it doesn't seem to exactly get at the hand rail problem.
Another thing you could try, is have a helper gently, or a little bit forcefully, pull straight up on the handrail as you tighten the screw. This may pull the nuts against the underside of the deck and hopefully create enough friction to hold them.
