  New Posts New Posts RSS Feed - 1st Gen SN parts
1st Gen SN parts
Eether View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eether Quote  Post ReplyReply Direct Link To This Post Topic: 1st Gen SN parts
    Posted: January-04-2016 at 5:30pm
This is probably a long shot but I'm looking for:
Windshield.. Yes I know... (probably will end up making one)
Morse throttle control. The shifter is dash mounted but I don't know if the 60s era Morse controller would be any different internally. Any info regarding the correct model number would be appreciated as well because it might be in a boneyard near me.
Correct vent scoops for the Front and back.
Mine never had any originally near as I can tell. At some point someone added two 2" front vents under a 70s correct craft front scoop.
Step pad frames and the pads. Two of the frames are somewhat serviceable but two are incorrect for the boat. None of the pads that go inside the frames are left. I've searched online for them but haven't come up with anything.
Any help is greatly appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2016 at 6:03pm
Are the pads and frames the same as the late 60's boats? If so do a search for step pads, someone was remaking them and N3 had them also. I thought Marty was looking into having step pad frames remade?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2016 at 6:23pm
We have 2 frames that are rough and need chroming we'll sell. I've bought pads from N3 and they are nice.
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2016 at 6:28pm
For Windshields you might look here:
NOS Windshields
It's an older posting, but at one time he had a lot of windshields, more pictures here"
Windshield Gallery
This place has some older CC windshields, specifically a 1968 18ft Ski Nautique, which appears to be the same as on the 63/64 Ski Nautique - call for availability:
UPD Plastics
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2016 at 6:37pm
Ethan,
Since you're regelling the boat, plug up the added vent holes. Looks like all there was were clamshells (standard Perko) on the gunnels at the cockpit bulkhead which is typical of 60's boats. The venting is then directed to the bilge via a duct or simply by the area created by the inside cockpit panels which yours won't have. Both my Atom and my X55 are set up that way. Go original!
JDD33 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDD33 Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2016 at 7:25pm
I have 4 frames with 4 black step pads from a 65 Mustang I would sell. Not perfect by any means but solid and straight.
I can get you some pics if you want.
Old school goin back to school!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eether Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2016 at 8:50pm
Thanks for the info guys!
N3 boat works in Indianapolis? I'll try them tomorrow as their online store seems a little lacking..
I'd be interested in your frames John. Pm or email pics if you have a chance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2016 at 11:01pm
Correct,N3 in Indy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eether Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2016 at 2:53pm
Fwiw, n3 doesn't have any step pads and they don't know if or when they will. Their source dried up apparently, but they are trying to find someone to reproduce them again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2016 at 3:29pm
Ethan,
It was Frank (FrankT) who was making them in fact, I believe the ones N3 had were his.
I see he hasn't been around since June so see if you can PM him. I talked with him several years ago because I was trying to reproduce pads for my X55. I wanted to know what compound he was using to cast the white since white casting urethanes turn yellow with the UV. He had found something that worked and I wish I remembered what it was. I need to write things down! I still have the mold that I pulled off an original. One of these days I'll go after the project again. Currently the X has generic pads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2016 at 3:56pm
Yeah frank found something that was uv stable. They were bright white. I believe n3's were from another source, I recall them being more off white.
ScottZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottZ Quote  Post ReplyReply Direct Link To This Post Posted: January-11-2016 at 3:50pm
I have a windshield. It is a Taylor Made that was used up to 1971. It is for sale. I may have some step pad frames and old inserts I will sell. Good luck finding new inserts. I may have some the old clamshell vents.
Lake Mitchell , AL
1984 Ski Nautique
1972 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eether Quote  Post ReplyReply Direct Link To This Post Posted: January-11-2016 at 4:13pm
Pm sent Scott. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottZ Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2016 at 1:35am
I have some step plate frames and original cc inserts.   I also have a morse control for a velvet drive too.
Lake Mitchell , AL
1984 Ski Nautique
1972 Skier
