  New Posts New Posts RSS Feed - Ski Tique Steering Cable
79CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79CC Quote  Post ReplyReply Direct Link To This Post Topic: Ski Tique Steering Cable
    Posted: April-19-2016 at 10:28pm
Hello all,
My steering is a little stiff to turn. Not muscle man stiff but stiffer than normal. I've poked around and don't see any obvious spots to lube the cable. Does anyone know if these cables are grease-able? and/or what procedure to take to lube it?
The boat is on my list to do a full out restore (maybe 3 to 5 years out from starting) but want to use it a few summers first while I setup shop, so, really not wanting to put a new cable in now.
Cheers,
'79 Ski Tique
79CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79CC Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2016 at 10:57pm
I know you guys like pictures so here ya go...
'79 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2016 at 11:52pm
Tom,
Disconnect the cable at the tiller arm to confirm it's the cable and not the rudder/port or helm. No, there's not a convenient way to lube them. Some have tried but I feel it's best to replace the cable if needed.
Nice Tique. Keep us informed on your progress.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2016 at 12:27am
I am with Pete on this one. Not a real good way to lube them. A friend has drilled a few holes along the cable to squirt small amounts of lubricant hoping it helps but still puts up with a crazy stiff steering wheel.. Order a new cable. It's well worth the money.
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2016 at 1:28am
Agreed. You should be able to spin the wheel with no effort. New cable is well worth the money.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2016 at 1:54am
For $100, I would not suffer with stiff steering for 3-5 years. Replace the cable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2016 at 11:12am
Its not worth waiting 3 - 5 years. Down at White Lake last weekend they knocked out a cable exchange between lunch and the afternoon water session.
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2016 at 12:16pm
He won't have to wait 3-5 years. The cable will snap long before that and then he'll be forced to change it. It never fails that it will snap at the most inopportune time too.
Eddie
79CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79CC Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2016 at 1:19pm
Thanks for the comments. I didn't think there was an easy way to lube that things. Its not the rudder, the rudder is on my kitchen table, repacking the rudder shaft stuffing. Yes, things seem to always break at the most inopportune times. The stringers and floors have been replaced once. Don't know if they tied that cable down in some inaccessible place (they did on the fuel line)... I guess there is only one way to find out.
Cheers.
'79 Ski Tique
