  New Posts New Posts RSS Feed - Thermostat leak
Thermostat leak
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Topic: Thermostat leak
    Posted: April-30-2016 at 8:17pm
Cameron:
Don't feel too bad about the thermostat-in-the-wrong-hole thing. Most of us wrench-turners have done something similar.
Nice DUI distributor...
CrazyCanuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrazyCanuck Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2016 at 6:04pm
What about a thermostat that has a rubber gasket?
Pic
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2016 at 9:28am
Originally posted by camron18 camron18 wrote:
i guess i should look at the "how water moves through the engine" thread.
I don't know if that will be much help! I read it and ended up feeling
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2016 at 10:16pm
Is there a thermostat in there now? If it is there maybe it's stuck open
camron18 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2016 at 8:33pm
well why do i never get up to temp? the gauge always hovers around 120
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2016 at 8:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2016 at 8:30pm
what????? well that makes it easy
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2016 at 8:28pm
Goes here   (redline)
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2016 at 8:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2016 at 7:12pm
Cameron,
Can you post some pictures?
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2016 at 6:37pm
Pcm 143 degree. Come side out spring into intake manifold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2016 at 6:31pm
Possible your putting it in the wrong place? Who marinized the engine PCM,Commander, Interceptor etc?
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2016 at 6:20pm
351. Thermostat form Skidim. The gasket from oriley. Could all those years of no thermostat cause the depression where the thermostat sits to fill in with rust??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2016 at 6:16pm
Or you have the wrong T stat? Fill us in with more info. Engine? Source of the T stat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2016 at 6:11pm
I've never had a thermostat in my boat. Last year I tyed to pop one in but I started it up and it was spraying water everywhere. So I said forget it I want to ski. This year I cleaned both mating surfaces got a new gasket and tightened it down. It still sprays water, which is dripping down and creating steam? Which I hope is normal..
Anyway there doesn't seem to be any indent for the thermostat to sit in. The intake manifold is flat and the housing is flat. I tryed gasket slealer which helped some.. But still leaks.
Bigger gasket? Should there be an indent?
Thanks
