  New Posts New Posts RSS Feed - Propeller for a 93 Nautiqe
kmayotte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kmayotte Quote  Post ReplyReply Direct Link To This Post Topic: Propeller for a 93 Nautiqe
    Posted: June-15-2006 at 4:27pm
I have a 1993 Ski Nautique with a 351 in it. My prop right now is a banged up 13 X 13 brass 3 blade. I mainly tow wakeboarders with about 500 pounds of ballast in the back and 4 people in the boat. It actually throws a mean wake for all who crap on the early 90's closed bow ski boats for wakeboarding. The point is...should I stick with my 13 X 13 or is there a better size or pitch for what I am doing with my boat that will optimize my hole shot and speed stability?
Get your money for nothing and your chicks for free.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2006 at 4:32pm
ACME 540
Munday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Munday Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2006 at 4:40pm
If you have a 1.23 to 1 gear reduction tranny thats not the right prop.my 92 runs a 14x16,a 13x13 is for 1 to 1 tranny
Munday
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2006 at 4:43pm
I was going by the 13 x 13 and not boat yr but good point, if he is using that small of a prop on the 1.23:1 tranny then he's giving up a bunch but reguardless get an ACME prop
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2006 at 9:10am
Its possible that he has the 1:1 tranny- a friend of mine has a '94 with one. Acme 540 or 542 in that case for sure.
If he has the 1.23:1, he'll want to take a good look at the Acme 470.
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2006 at 10:01am
I am a big fan of the OJ XMP I would doubt there is any significant difference between its performance and the Acme 54x series I would go with whichever one was cheaper.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2006 at 10:36am
Joe, I agree- ETS on the Mastercraft forum compared the Acme to the OJ XMP and the results were pretty even.
However, I think the only OJ XMP props that are RH are 4-blades for the 1.23:1 CC boats. Your motor is standard LH rotation, correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kmayotte Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2006 at 9:09am
my boat is a right hand rotation. Still waiting on the transmission because its in the shop and I haven't seen it since I posted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2006 at 12:01pm
Kmayotte, almost all CC's came from the factory with RH props- both 1:1 and 1.23:1 trannies. My comment above was directed at JoeinNY, as I *believe* he replaced the motor with a LH version and turns a LH prop.
If youre not sure which transmission you have, you can tell by the engine code, found on the PCM tag on the intake manifold. I know one of the letters indicates the transmission- I cant remember which one it is, but I do know that a PRDxxx motor will be reverse rotation and use the 1:1 (13x13 prop) while the PLDxxx motor will use the 1.23:1 (14x16 prop).
