  New Posts New Posts RSS Feed - Transmission will not go into Neutral
valveman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote valveman Quote  Post ReplyReply Direct Link To This Post Topic: Transmission will not go into Neutral
    Posted: June-17-2006 at 9:59pm
I was coming up to my dock and the boat would not go into neutral and I checked the fluid and it is OK. The boat will crank up in gear and will stall out if I go to far in the reverse position.Any Ideas??
Thanks
Jerry
I have a 1979 Ski Nautuqie
pn48513 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pn48513 Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2006 at 10:41pm
i have a 79 with the same issue. the response i have gotten is that the tranny has too much fluid or the clutches are adjusted too tight. let me knwo what you hear.
Bradley950 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradley950 Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2006 at 11:49am
I over filled my trans and the same thing was happening to me last summer. Try sucking out the fluid and putting in fresh. With the trans level it holds 1.8qts at a 15 degree incline it holds 1.3qts. Keep in mind this dose not include the trans oil cooler, so if you have a trans oil cooler it will take a little more. This fixed my problem.
Brad Miller
bradley950@yahoo.com
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2006 at 12:02pm
I would look at the cable adjustment instead of messing with the fluid level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote valveman Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2006 at 2:40pm
Thanks for getting back guys about my tanny,
One more thing is that the unit when it is in neutral it rolls pretty good down the lake.I have took the linkage loose form the shifter and put in the neutral by hand on the gear box and it still turns the prop very fast.
Thanks
JB
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2006 at 2:52pm
you must have too much fluid in it or it's time for a rebuild
Post Options Post Options   Thanks (0) Thanks(0)   Quote valveman Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2006 at 3:02pm
I'm going to try to flush and refil this weekend and if not then I am going to replace it.
Thanks
JB
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2006 at 4:14pm
just add a qt after it's drained, then see if it does the same thing you should be able to stop it by hand, well I use my foot, to stop the prop shaft if it doen't then something is broke internally.
Second thought just start by remove some fluid and see if it helps, just a little at a time. No need to waiste money on new fluid if your just going to have to pull it apart to fix.
