  New Posts New Posts RSS Feed - Tranny fluid in bilge water?
wlentz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wlentz Quote  Post ReplyReply Direct Link To This Post Topic: Tranny fluid in bilge water?
    Posted: June-18-2016 at 12:36pm
Dipstick shows nice and pink...does not show fluid as being low, but noticing oil residue in bilge area under tranny and in bilge water...seems to be shifting normally...gasket?...overhaul?...any suggestions on what is going on? Thanks!!
Peacock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peacock Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2016 at 11:18am
Following post. Found same issue this weekend. I think mine is rear seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2016 at 11:19am
probably seal.
pink as in red fluid plus water?
you want red
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2016 at 12:23pm
you want red
I agree. If you have pink, waters gotten in. The first thing to check would be the trans cooler. Pull it and pressure test it.
