  New Posts New Posts RSS Feed - will not start carb issue
tommer12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommer12 Quote  Post ReplyReply Direct Link To This Post Topic: will not start carb issue
    Posted: June-24-2006 at 1:31pm
I have posted in a few forums here on a related topic. I replaced my power valve and put all new gaskets on the primary and secondary... go to fire it up, and it will not start. If I hold the throttle wide open, she will pop and start, but just rev up... sounds like it is just suckin a ton of air in.
Any tips on getting it steady again.. or I am just spinning my wheels.
92' nautique PCM 351 ProTec Electronic ignition
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommer12 Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2006 at 3:24pm
Ok, I'm pretty much giving up on this piece of crap carb.   Anyone want to recommend a new carb for me? 4160 to replace this one?
Thanks
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2006 at 10:45am
take it and have it re-built by someone knowledgeable instead of buying a new one which is just a waiste of money when you already have a carb that can be re-built
Munday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Munday Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2006 at 6:08pm
I love my fishbowl carb,if you replace it post the old one in parts for sale.But like 79 said
its not the carbs fault,you just missed something
Good luck Munday
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommer12 Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2006 at 8:00pm
I just found out from the original owner that it has never been rebuilt... so this would be the first rebuilt.
So my dilema is:
Rebuilt carb locally here is $289.00, tested on a 351,etc.
New 4160 $449. sell my old one for $150? Then just have a brand new one.
I checked out fish.... not bad on prices.. don't like the black that much.. but oh well.
I probably did miss something, but I have a feeling I will get it fixed, then 2 weeks later something else goes wrong with it and i'm out another weekend or two fixing that problem.
Any input?
thanks fellas!
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2006 at 12:26am
If you get it rebuilt by a qualified shop it will be as good as new.
You asked for more input: Get it rebuilt.
In fact, if it was me, I'd be sure to get the carb rebuilt and not exchange it for a rebuilt - keep the original. I think you will have fewer problems by hanging on to the original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2006 at 7:36am
289.00 a bit high concidering he's only got 50 bucks in kit, and about 1 hour in labor time not including the soak time, which doesn't invaul any labor.
fredo68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredo68 Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2006 at 11:31am
that is expensive, i had an auto repair
shop rebuild mine he took it off the boat
rebuilt itand put back on for 150. boy
did it like having that done its like a
new boat.
fredo68
fredo68
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommer12 Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2006 at 1:52pm
So I went with the rebuild.. They are taking my carb and pulling it apart. They did find a bad accelerator pump which was the first cause of my backfire out of the hole, which then probably took out my powervalve.   I did happen to replace my powervalve and put it all back together... but then I had the problem above. Apparently, it is possible to get a bad powervalve from Holley out of the box... it's not uncommon from what I was told.
Anyways.. I'm hoping for that "new" feeling this weekend when I get it back together.
cheers.
