started buffing my 93 S.N. |
Post Reply | Page <1234> |
flyweed
for those of you guys following my thread...I am looking for a photo or image of the dash mounted mirror/bracket for my 1993 SN.
I have purchased a new mirror, and the "bracket" is still mounted to the dash on my boat, but I am missing SOMETHING that makes the connection from the bracket to the mirror, and need to see what it is, so I can fabricate one, or buy one. |
flyweed
Well, Get goin'.......what r u waiting for!! |
Dreaming
Looks AWESOME, nice work!
KRoundy
Wow. Well done!
Now I have no excuses left - I need to do the same for my 1993 machine. Time and elbow grease... |
flyweed
couple more side shots. this side was the WORST....tons of "dock rash" and scrapes. some scratches were pretty deep. But they ALL came out!! I am really happy with the results.
flyweed
Yes I did. got the pinstriping ordered already. I got the medium grey coming for the bottom striping and the light grey ordered for the upper (between cranberry and charcoal grey) striping. Plus I have all the decals here already that match all of the ones I took off.
velde99
Platinum Member Joined: November-04-2012 Location: Tampa Florida Status: Offline Points: 1108 |
Did you get links for your pinstripe tape?
flyweed
yep, that's what I figured....so decals are next! probably this weekend.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21132 |
Decals before wax
flyweed
Ok...done polishing. Just have to WAX yet......LOOK AT THIS SHINE.........my old 1993 is gonna be HOT again! :)
quote any link and you'll see what is needed. then, just type in the URL bracket stuff by hand, pasting in the actual address where it goes
the buttons are just cheaters, everything the buttons do you can do by hand if you know the "codes" |
velde99
Please explain that- so I can do links in future- thanks
hyperlinking with an iphone works fine you just have to do it manually
velde99
Thanks for fixing the link. Not sure why iPhones don't work on the site.😜
JPASS
'92 Correctcraft Ski Nautique
velde99
Light grey is what you need between the cranberry and grey.
https://www.ebay.com/itm/300728352402 |
velde99
I have become somewhat of an expert trying to find pinstripe tape. 1/2 & 1/4 double line tape is usually custom made. Zach at N3 used to get it for us. Not an option now. Plus it was EXPENSIVE! So eBay has a company that has almost exactly what you need, but you need to buy 1/2" as well as 1/4" rolls and do it manually. Medium grey is what you need. I just did my boat- and it is a close as you'll find without going custom.
Here is link- that you'll need to copy and paste. You'll need to do two rolls. $33 is a steal. Hope it helps. Link #1 https://www.ebay.com/itm/300728346193 Link # 2 https://www.ebay.com/itm/300728352402 |
White lake or n3 may have the 1/4-1/4-1/2 double pin. You need a 1/2" pin between the charcoal and cranberry.
flyweed
Relake...
aint' NO amount of 3M remover/wax would work on taking the scratches and shadowing out that was on my boat sides. I used EXACTLY what Pete just posted a link to up above. This process works perfectly. I did use a variable speed rotary polisher that saved some serious arm fatigue..but I still did MOST of the wet sanding with a rubber block. Here is a photo of the worst side damage from "dock rash" |
Gel coat thread out of the FAQ's in the maintenance section |
relake
Senior Member Joined: May-18-2016 Location: IN Status: Offline Points: 126 |
Depends on the amount of "damage" on the gel coat, upload a few pics of your ride so we can see! I simply used the 3M one step oxidation remover/wax, went over it multiple times (by hand) and the results were very good.....still not where I want it to be, but getting there. |
Wisky Badger
Senior Member Joined: July-02-2015 Location: Wisconsin Status: Offline Points: 218 |
Your progess looks terrific. Can you detail the steps you used I.e. what grit sand papers, what type of cutting compound and polish? Also did you use a rotary air sander or do it by hand?
The family just picked up a winter project so I am trying to read up on all these threads and gain as much info as possible. |
relake
Looking good, keep it up......I'm in the same boat, looking for a 1/4" purple pinstripe for mine......I may just order from a Google search on the purple and try to match best I can
flyweed
Also, I know I can get the 1/4" grey pinstripe from Nautiqueparts, but anyone know where I can get the double grey strip at the bottom?? I didn't see it on the Nautiqueparts website.
flyweed
Hey guys...few more days, and a couple more photos. ALMOST THERE! First photo is after FINAL sanding. 2nd photo is after first polish. It was overcast, so it's hard to appreciate what it looks like. but if you look at the trailer guide, you can see how easily it Mirror images in the boat finish. I even got rid of ALL the shadow from the old lettering on the boat.
Tomorrow will be final polishing filling the couple dings you can still see by the trailer wheel yet. and then finishing her up. final sanding done first polish |
fgroce
If I remember correctly our 88 2001 came with white wall tires when we bought it new in 88.
Frank |
FGroce
phatsat67
Mm mm, white wall trailer tires. |
KRoundy
That looks amazing. For what it is worth, my 1993 has a bit different graphics package than your (later build I think) and it has two solid 1/2" stripes. One on the top and one of the bottom. But, I don't have the "world" graphic like you do either. A look at the 1992 and 1993 brochures would show the differences.
Blamey
Gold Member Joined: August-18-2015 Location: White Plains,NY Status: Offline Points: 631 |
For that to be the case the writing would be backwards on one side.
96 Super Sport
Previously: 95 Sport Nautique, 1980 Ski Supreme |
flyweed
Ah...didn't know that...so one goes one way, and the other goes opposite? I figured each side would have decals laid out to look the same and mirror the opposite side.
