Engine drain plug |
Author | ||
leftseat88
Senior Member Joined: July-06-2009 Location: Toledo Ohio Status: Offline Points: 106 |
Posted: September-19-2016 at 10:59pm |
Evening All,
I have a 96 Sport with the GT-40 with EFI. While winterizing, I managed to strip the threads out of the "block" on the Starboard brass drain plug. Not only are threads gone in the block, the threads are pretty much done on the plug. Has anyone done this before and how do I fix it. Thanks |
Drill and tap to 3/8 NPT.
leftseat88
Wow, that was fast, thanks. Any idea where I can find the new brass plug. Can I assume I need a brass plug?
Home Depot!
Duane in Indy
McMaster Carr sells brass pipe plugs Another alternative could be to use a Stainless Steel Hex Nut Expansion Plug for 7/16 Pipe Size $6.87 Each #2599K27 (tap drill size for 1/4" pipe is 7/16")
I recommend using Petes answer, but not everyone has access to or knows how to drill and tap a block with the engine in place. |
1978 Mustang (modified) |
I would run a 1/4" npt tap through the hole first, the tapered pipe threads may allow you to save it without upsizing. Any hardware store will have the plugs- go with brass.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
I like the way Tim thinks, definitely worth a shot, it's worked for me and at other times it hasn't Nothing to lose doing this first. |
I too like the idea plus, brass male fittings have a tendency to run oversize so with just chasing the block, it may work. |
