  New Posts New Posts RSS Feed - Need some help with Part numbers
workky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Topic: Need some help with Part numbers
    Posted: January-03-2017 at 7:45pm
I know we have a poor mans gt 40 diagnostics page with a spreadsheet, i was wondering if anyone put together part numbers for sensors and whatnot. I need a few things that some marine places have, but they are ford parts. I would like to know if someone has a spreadsheet somewhere or could offer some advice on the following parts for a 1995 SS with a 351 GT-40 multi port injection system, not the throttle body. Im not saying my boat needs all of these things, but she is getting old and we want her running in tip top. I know im needing to replace a few things just for preventative maintenance. But int he future im sure some of these items will need replacing and i want to make sure i have the correct parts.
Low Pressure fuel pump- I think its a carter 4389
Map sensor- was going to it take off and take to Ford for part number matchup
anti syphon valve-I have no idea
Water temp sensor-in the intake manifold the sensor not the sender
Air temp sensor-
Oil pressure sending unit-the one that operates the gauge
TPS sensor-
Relays- Fuel and ECM
Fuel pressure regulator
Ignition module thick film thinggy
Resource for push button breaker on the dash and also the ratings for them, or possible advice for converting to rocker panel switches.
Any help with motorcraft or PCM partnumbers would greatly be appreciated. I don't mind aftermarket, but i prefer PCM or motorcraft
Thanks for any help or advice. I know ski dim and nautique parts have some of these items, or i could not find them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: January-03-2017 at 8:17pm
You can find some things with a little digging such as this thread but it would be great to have everything on the spreadsheet,(hint hint) gt40 spreadsheet
Ignition module thread here
