  New Posts New Posts RSS Feed - OMC 350 Rebuild Questions
Benni27 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Benni27 Quote  Post ReplyReply Direct Link To This Post Topic: OMC 350 Rebuild Questions
    Posted: February-08-2017 at 5:00am
Hey Guys,
I'm thinking about a rebuild of my OMC 350 because of bad Heads, low Compression and ~2500 hours on it. I took of the Heads an all assembly's and had a look at the Block number: GM3970020. Google told me that it is a GM 307 Block (5.0L?!) instead of a 350. Does someone have more information about the OMC 350? Did they build a 350 out of a 307 Block with 350 crankshaft an pistons?
Boat is a Ski Nautique from 1979, but I don't know if its the original Engine. Color, Intake, Carb looks like origin...
Thanks for the help
Ben
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2017 at 6:01am
Pretty simple math. With the heads off check the bore and stroke.
Pi. (3.1415) X r. X r. X stroke X # clys.
Don't have the correct symbols on my keyboard    3.1415 X radius squared X stroke X #cylinders
edit:   305 and 350 have 3.48 stroke
           305 bore is 3.736
            350 bore is 4.000
        1978 Mustang (modified)
swilliams View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2017 at 7:46am
Ben, you are correct about the block being a 307. If we had your model number, that would be helpful. Omc made a 230 hp that would correlate with your block number. I have a 260 hp 350 ci motor in my 76' Martinique. Most engine parts can be found as it is a GM product. Pics are helpful. I also hav e a service and parts manual that could possibly cover your model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Benni27 Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2017 at 8:29am
Here are a few Links. Some old pictures and new ones:
pic1
pic2
folder with pics
It should be the 260HP model. This is what is in the papers... Could you send me the Service an Partsmanual :)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2017 at 9:16am
OMC manual
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2017 at 10:40am
Duane gave you what you need to know for figuring the displacement.
He gave you numbers for a 305 chevy instead of a 307 chevy though.
A 307 is 3.87 inches bore and 3.25 inches stroke.
Stick a ruler across the bore for a quick and dirty check.
4 inches would be a 350
3 7/8 inches would be a 307
Post Options Post Options   Thanks (0) Thanks(0)   Quote Benni27 Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2017 at 11:44am
Quick and Dirty Check was:
Stroke ~3.25
Bore ~3.87
So it must be a 307... Heads are 3973487X 76cc from a 350? I'm a little bit confused, maybe I should order the Parts Manual at marineengine.
What's the best adress to get parts from? I thought about summit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2017 at 1:43pm
I can't send you the manuals but let me see if your model number is included in my service manual. From there I can tell you which manuals to look for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2017 at 3:31pm
Steve,
Nice gesture but beware. Here's the notation that marineengine.com has on their OMC manuals:
"† Please Note
OMC created new manuals each year which are specific to various models. When ordering a factory manual you must include the year, horsepower and/or displacement, and most importantly the OMC model number of your engine."
Your OMC is a 76 and Ben says his is a 79.
Post Options Post Options   Thanks (0) Thanks(0)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2017 at 6:38pm
Pete, my manual shows a long list of model numbers that it covers. If his is there, then we are golden. I believe my parts manual is set up the same way. M service manual does show a 350-4(which his is) and the specs for it. We'll get him there!
Post Options Post Options   Thanks (0) Thanks(0)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2017 at 6:45pm
Ben, can you provide me a pic of your raw water pump? Just curious if its the same as mine. I know OMC made a change in them after my year but not sure when. Finding parts for mine is tough. Thanks, Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2017 at 7:22pm
Sounds to me like you should be looking for a 307, since that what his measurements taken earlier today and his block number says too. You even said 307 earlier
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2017 at 7:35pm
307 wouldn't have come in a '79... 305 took its place several years earlier. Exh manifolds look correct for late 70's, decals suggest a 307 block took the place of the original 350 at some point in the boats life, which was dressed back up with the original 350 parts. Just a theory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2017 at 9:27pm
I agree with Tim. My service manual does have your model number listed but the general specifications say it is a 350. Your block number is definitely not a 350. Do a search on the head casting numbers. Bet they are not for a 350.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2017 at 10:28pm
Is that bet just with Benni27 or can I get in on it?
Chevy literature says the heads are for a 71-72 350 and they're a pretty good set of heads. Benni has already looked this up by the way. He mentioned that they're 350 heads a few posts back.
The block is a 69-73 2 bolt main 307.
This info probably pertains to auto engines and we all know that marine conversions can be a mix of different parts
The OMC model number says it's a 350 4 barrel like you already pointed out. Model year 1978 according to Marine Engine.com. That's hard to explain.
I see from Benni's pictures that it is a RH rotation engine.
mark c View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark c Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2017 at 5:16pm
Heads are a 71-72 350 Chevy Head 76cc combustion chamber with 2.02/1.60 valves. The heads with the same casting number without the X suffix have 1..94/1.50 valves. Originally came on the LT-1 engines.
